Author Topic: Wtb: 1.6td oil filter bracket  (Read 4256 times)
January 03, 2014, 11:55:33 am
rumbling_caddy
  • 80
« on: January 03, 2014, 11:55:33 am »
Found what I need.  No longer looking
Thank you all
« Last Edit: January 10, 2014, 09:57:12 pm by rumbling_caddy »
Reply #1January 04, 2014, 11:18:04 am
RustyCaddy
  • 395
Re: Wtb: 1.6td oil filter bracket
« Reply #1 on: January 04, 2014, 11:18:04 am »
Might be part of what you are looking for (don't see the long nipple or nut for the oil cooler)...not mine or anyone i know:
http://www.ebay.com/itm/vw-1-5-diesel-oil-filter-housing-1-6-diesel-oil-filter-housing-vw-055-115-417-G-/161189997653?pt=LH_DefaultDomain_0&hash=item2587ac2c55
Reply #2January 07, 2014, 12:01:02 pm
  • 2926
« Reply #2 on: January 07, 2014, 12:01:02 pm »
 I have a spare TD oil filter mount but I'm not going to ruin a turbo oil supply line to get you the fitting.
Reply #3January 09, 2014, 09:44:07 am
TimpanogosSlim
  • 590
    Pretty dumb for a smart guy
« Reply #3 on: January 09, 2014, 09:44:07 am »
It sorta looks like you could just drill and tap what you already have?
Reply #4January 09, 2014, 11:43:38 am
rumbling_caddy
  • 80
« Reply #4 on: January 09, 2014, 11:43:38 am »
I tried the the drill and tap method already.  It's easy the strip the tapped tread and tricky to that area to seal.   With lots a Teflon tape and a few tries I did finally got no oil leak.  However I would prefer the correct part for more reliability
Reply #5January 09, 2014, 12:22:08 pm
TimpanogosSlim
  • 590
« Reply #5 on: January 09, 2014, 12:22:08 pm »
Ah.
Drill, tap, and helicoil. And thread high temp thread sealant.
But i don't blame you for wanting the right part. Good luck.
Reply #6January 10, 2014, 01:06:34 pm
  • 2926
« Reply #6 on: January 10, 2014, 01:06:34 pm »
 Much easier to drill and tap if you have a drill press and a vice.
 Drill it
 then put the tap in the chuck and turn it by hand following the same path as the drill.
 Until it's started good,
 then use a 12 point socket or T-handle to finish the threading.
