Author Topic: Door Lock Help  (Read 4419 times)
December 26, 2013, 02:24:34 pm
ReubenG
  • 46
Door Lock Help
« on: December 26, 2013, 02:24:34 pm »
'81 rabbit pickup
my drivers side door will not lock from the outside with the key. It also will not lock when the door is open, using my hand.
BUT it will lock when I'm sitting in the truck...
new tumbler???
Reply #1December 26, 2013, 04:39:41 pm
Re: Door Lock Help
« Reply #1 on: December 26, 2013, 04:39:41 pm »
Maybe just a pull apart and clean.  Once you get the door card off it isn't that much work to get the tumbler off and in your hand to clean it.  I soaked mine, an 81 Rabbit, in cleaner for a half a day and I was amazed at all the gunk that came out of it.  If that doesn't do it then I would think the key is worn and not doing its job.
Grinding another and not trying to make it perfect might add enough on the edges to get you back in the door from the outside.
Had to do that once as well.
Reply #2December 26, 2013, 06:53:11 pm
Re: Door Lock Help
« Reply #2 on: December 26, 2013, 06:53:11 pm »
It is impossible to lock any (I think) VW drivers side door from the inside with the door open. Even with power locks you can't do it.
Did that key ever work in that door for unlocking/locking?
You can access the tumbler by simply removing the exterior door handle from the door. Insert the key into the lock and take note of the tumblers. If any are sitting proud you can take a file or grinder and file them down smooth. Then the key should work fine. There are some good threads out in www land that explain what I'm trying to say.
Reply #3December 26, 2013, 10:19:08 pm
Re: Door Lock Help
« Reply #3 on: December 26, 2013, 10:19:08 pm »
I agree... They are genius-proofed.
Yep. Sometimes, I will simply remove an offending or mismatched tumbler (wafer pin). There are enough to go without one or two. If you collect a few handles at the boneyard, you can usually re-pin the ones you use.
« Last Edit: December 26, 2013, 10:22:45 pm by TylerDurden »
Reply #4December 27, 2013, 10:12:55 am
  • 1739
Re: Door Lock Help
« Reply #4 on: December 27, 2013, 10:12:55 am »
the cylinder and door lock [golf tee] are 2 different parts of the door locks. The door will not lock either way if the lock is not in it's closed position[ door open or closed]. Take out the cylinder, it is worn, but can be cured by removing any tumblers that are sticking out when the key is inserted
Reply #5December 27, 2013, 03:00:36 pm
ReubenG
  • 46
Re: Door Lock Help
« Reply #5 on: December 27, 2013, 03:00:36 pm »
excellent I'll take a look!
Key works good in passenger door, so that's probably not the issue.
Pin functions properly as well, so must be the tumbler/cylinder
Reply #6December 27, 2013, 11:16:23 pm
Re: Door Lock Help
« Reply #6 on: December 27, 2013, 11:16:23 pm »
This sounds like the normal, factory intended behavior. You can't lock the driver door when it's open. You can only lock it when it's closed.
Reply #7December 30, 2013, 08:44:53 am
ReubenG
  • 46
Re: Door Lock Help
« Reply #7 on: December 30, 2013, 08:44:53 am »
Right. Gotta fix the tumbler/cylinder
