'98 Jetta misfire on cold start, lacking power when cold
by
CrazyAndy
on 27 Nov, 2013 04:56
Hi all,
So I finally broke down and bought a modern car, a 1998 Jetta TDI. Some history on the car: Guy bought it w/ broken timing belt, bought rebuilt head, new injectors and glow plugs, and head gasket (I asked him about the notches, he said original HG was 2-notch, and that is what's on the car now). It needs a new starter switch, and the PO before him, installed a remote button to get it started. Also, for some reason, installed an Audi radio of comparable vintage. Got it home 98 miles, and the very next morning started having a misfiring issue when starting cold (16 deg F). It is repeatable, happening every time it starts after sitting for over 5-6 hours. The first 2-3 starts it dies after stumbling for about 5 seconds, with blue/white smoke coming from the tailpipe. After eventually getting it to start and idle, attempting to accelerate, either from a stand still or while moving, causes it to stumble and die again. Once I let it run for a bit I am able to accelerate without it bogging down, but feels gutless until about 2400 rpm, with smoke front he tailpipe and sometimes feeling like the turbo is not spooling.
Checked so far:
-Pump cog and cam timing (OK)
-Pump internal timing w/ VAG-COM (over advanced, readjusted; problem still persists)
-Will install fuel filter today
What the hey could be causing this issue? Could the PO have botched the head job (what I'm leaning towards)? Could I have air getting into the pump (saw some bubbles from filter feed line; tightened clamp and diminished; hope internals aren't cavitated)? Is there a sensor that can go bad, causing this to happen? Ignition switch causing this, or K-wire feedback due to wrong radio? I know this thing can run good, It's done it before. Any ideas would be appreciated.
Thanks!
#1
by
on 27 Nov, 2013 05:03
more than likely, it is just air in the line.
#2
by
CrazyAndy
on 27 Nov, 2013 05:05
Or a seal in the pump letting it in, an unlikely but possible alternative. I'll update after fuel filter install. Are there any parts of the MK3 fuel system besides the pump inlet and return lines that like to leak? Injector return lines?
#3
by
on 27 Nov, 2013 06:00
I would guess the air in the pump would help starting. It maybe that the compression is down and after their head work they decided to get rid of it? I would pull the injectors once you have it hot and do a check. It won't hurt anything. Definitely fix your air.
Also as a side note when they did the head, did they used new nozzles in the injectors? If not I would say it is due.
#4
by
on 27 Nov, 2013 06:28
Ha ha, that's funny. 15 years old isn't exactly modern. It's more than halfway to being an antique car!
#5
by
on 27 Nov, 2013 06:31
funny but that is the way I see it too, anything newer than 90 seems pretty new to me
#6
by
on 27 Nov, 2013 07:36
I remember when I was a kid, when my folk's car was 10 years old it was OLD. Now my '02 Jetta wagon seems like a spaceship.
#7
by
CrazyAndy
on 27 Nov, 2013 09:46
I DROVE an antique before this. This has heat, power steering, a radiator, an ECM, A/C, and a radio that has more than 2 speakers. It's modern (enough).
#8
by
on 27 Nov, 2013 12:17
Sounds like classic fuel filter plug creating a vacuum on run then when it sits air leaks back into pump causing start/run issues.
You could bottle feed it a while and see if that keeps it going or runs without the lag.
#9
by
CrazyAndy
on 27 Nov, 2013 15:14
Update on runing concern:
R and R fuel filter; concern persists. Tested flow before and after fuel filter replacement; low flow in both tests. R and R pressure line to ECM for fault '65535 - Internal Control Module Memory Error' as per
http://www.myturbodiesel.com/1000q/a3b4/ecu-hose-chip-tdi-65535.htm (pretty nice 1000q); concern persists. Visually inspected body fuel supply lines from filter to fuel pickup tube; no external damage present. Next diagnosis step is bottle feed test as per ORCoaster recommendation, and in-tank fuel pickup flow test.
#10
by
dieseljunkie69
on 27 Nov, 2013 15:25
It has been ten minutes.
How did this workout?
#11
by
on 27 Nov, 2013 16:55
Isn't that car supposed to have an electric lift pump?
#12
by
CrazyAndy
on 27 Nov, 2013 19:46
Ran out of time, temperature, and daylight. I'll try Friday and/or Saturday, as tomorrow I have Thanksgiving family crap to do.
Nope, that's Mk4's, Mk3 and B3/4 TDIs still relied on the pump's own internal vacuum to draw fuel. Sucks, don't it? I could install a lift pump, but that is dependent on if the pickup filter is clogged or not obviously.
P.S.: Anyone got a lead on new or good used Mk3 TDI Jetta fuel sender assemblies? I have a bad feeling these things are NLA, as google searches on the part number just turn up Chinese copies. No tank you.
#13
by
on 27 Nov, 2013 22:12
If you have a lift pump, I'd install it temporarily as a fast way to do a leak check
#14
by
on 28 Nov, 2013 03:40
bad glow harness... kicks on light.. one or 2 plugs dead.. so colder then others an dmisses makes smoke..
