#15
by
on 14 Oct, 2013 21:23
I'm truly baffled by all the nastiness coming from the E-crowd on this topic. Ignorance is a dish best served alone.
It reminds me of the sentiment on the Samba that diesel destroys transmissions.
#16
by
Zeitgeist
on 14 Oct, 2013 23:54
Exactly.
#17
by
on 15 Oct, 2013 07:28
I love VNT turbos, I really enjoy computers, programming and electronics and my farts smell awesome. "Everyone Likes their own brand."
http://www.youtube.com/watch?v=H_BGyLZhY40
haha i do as well, i actually went to a vocational high school for electronics and work with electronics every single day.
my farts smell like a fresh loaf straight from the oven, whats not to enjoy?
also i have driven diesel vws for almost 10 years now and i have never had any problems with a transmission.
#18
by
G60ING
on 15 Oct, 2013 22:25
I'm an e-Tdi swapper because I like reliable performance and trouble shooting. I've poked around here for a while and I know there are numerous mtdi pump build threads. I've seen a good number of mtdi low performance threads on the Tdi club. If it was so straight forward and easy to build an mtdi pump wouldn't there be a simple source for the mtdi pump? Pay $700-$1000 and be done. If people built a list of all the ingredients: x injectors, such and such turbo with this guys mtdi pump and you will have 1?? whp and 2??wtq I bet you would make a lot believers. I would be one
The people that report good results are the ultra hardcore gdi peeps.
#19
by
on 15 Oct, 2013 22:35
why my rover pump experiance kills all that... cheap, damb near bolt on.. the gov mod is simple.. not like opening rest up.. and on stock tdi.. a e way slower.... add 50 hp... right now...
#20
by
on 15 Oct, 2013 22:54
They have their cool license plate frames though... We should get our own.
#21
by
dieselherb1
on 15 Oct, 2013 23:40
But I love my cruise control. Really I just a couple of Rover pumps to put in Caddies, we'll see!
#22
by
G60ING
on 15 Oct, 2013 23:45
Make a quick and simple list of the parts to make x amount of power. Post it up with some of your experience, iirc your thread is uber long. newbies need the reader digest version:) I'll be happy to add it to the tdiswap list and make it stand out.
I like my cc and license plate frame, it works on my car. If you came up with one that worked with my plate i'd rock it.
#23
by
on 16 Oct, 2013 00:46
There are no changes necessary to the internals of the Land Rover pump to make considerably better power than a stock eTDI. Any nozzle change suggestions for eTDIs for a given amount of boost apply directly to mTDIs.
#24
by
on 16 Oct, 2013 01:18
it is just like fitting a mk4 pump on a mk3... pics on tdi club... pully/mount mods..
gov mod in 8v sig..
fab some type of throttle cable mount/linkage
fab the rear under line mount... or swap it..
swap delevery valves
mine is timmed at 118.. im real happy with it and still not touched it.. i hear 130-150 good.. but never tried.. if happy why mess with it imo.. same on fuel screw and boost pin... still on stock settings even w/gov mod... makes very little soot.. and egts only exceeded 1250 1 time... and blew the turbo in this moment... drove turbo aditional 5k before i figured out that i blew it!! toweed car home and all...
im real happy with my tdi m
and when i got mine.. 200ish ebay uk... what guy paid for it that i got it from.. i manned up to play guini pig.. and impressed with doing it..
mr herb... cruise is cake... upgrade section i have a thread on stock vw cruise... the only issue.. throttle springs too strong for the vac ball.. so need to experiment with them to reduce that aspect a tad.. i keep telling bbob thats why his no work... 1.6 throttle lever has softer springs then my rover pump or his libby pump.. and for how tight my rope/dead mans cruise worked i can see that as why.. (lack vw speedo head fo vw cruise)
i think cross planting a mk3 gasser cruise to tdi e harness would get you cruise on a mk3 tdi-m... so no reason at all it cannot work.. else mk1/mk2 vanagon and such can use that part list..
#25
by
Zeitgeist
on 16 Oct, 2013 01:25
Cruise control works on manual pumps, too.
#26
by
bbob203
on 16 Oct, 2013 07:37
CRS you gotta watch. I still haven't confirmed that tidbit about the cruise. I really don't think thats my problem.
#27
by
on 16 Oct, 2013 09:52
While the governor mod will increase high rpm power, the stock Land Rover governor spring gives the full rpm range of the eTDI.
#28
by
bbob203
on 16 Oct, 2013 10:04
Could it be done on my pump?
#29
by
on 16 Oct, 2013 10:49
Not exactly, the Cummins governor spring setup is different (uncaged) and cannot be shimmed in that way. I do have a slightly shorter and stronger uncaged governor spring that I would be willing to send to you to try if you want. The shorter/stronger spring gives the same effect as shimming the caged governor spring.
