Author Topic: Stuck in the Driveway  (Read 9726 times)
January 24, 2013, 11:20:09 am
mtnbob
  • 738
« on: January 24, 2013, 11:20:09 am »
86 Golf 1.6TD-----Car wouldn't start this morning, thought it was the loose alt belt. Charged battery, cranked many times, but won't start. Changed out the fuel filter, checked the air filter, still nothing. Any suggestions on the logical way to go about this?
Thanks
 8)
86 VW Golf 1.6 N/A 4-door (soon to be turboed!!!)
http://farm4.static.flickr.com/3248/2598033828_d3d19f9842.jpg?v=0
96 Subaru Outback Wagon
Reply #1January 24, 2013, 12:00:56 pm
mtnbob
  • 738
Re: Stuck in the Driveway
« Reply #1 on: January 24, 2013, 12:00:56 pm »
I finally got it started and it is running ok   but I noticed that I am getting exhaust smoke? under the hood. Is it possible to have a bad connection between the manifold and the downpipe? Where else might exhaust smoke be coming from?
Reply #2January 24, 2013, 12:22:57 pm
« Reply #2 on: January 24, 2013, 12:22:57 pm »
Gaskets at head between Manifold could be mis oriented.  Two go one way two the other.  Might be preventing head/mani clamping tight.  Also downpipe might be turned and pushing exhaust by o ring?  Clamps tight on that toilet bowl thing?
Reply #3January 24, 2013, 12:24:34 pm
mtnbob
  • 738
« Reply #3 on: January 24, 2013, 12:24:34 pm »
They look good at the downpipe connection. Is it possible that the turbo is coking up and not working? Plugging the intake? Please excuse my ignorance on this subject.
Reply #4January 24, 2013, 08:21:17 pm
« Reply #4 on: January 24, 2013, 08:21:17 pm »
does it have a POP sound? if not its after turbo... look for hole... pop/click/tap is pre turbo...
Reply #5January 24, 2013, 10:43:24 pm
Dakotakid
  • 1240
« Reply #5 on: January 24, 2013, 10:43:24 pm »
My guess is that it will quit smoking after you burn up all that fuel you injected while trying to start it.
Reply #6January 25, 2013, 03:37:22 am
mtnbob
  • 738
« Reply #6 on: January 25, 2013, 03:37:22 am »
I got it started drove it 75 miles, and now its stuck again. Battery is fully charged. It just doesn't seem like it is getting any detonation. Glow plugs?  Do they go all at once? Car started fine in cold weather just three days earlier.
Reply #7January 25, 2013, 04:00:27 am
air-cooled or diesel
« Reply #7 on: January 25, 2013, 04:00:27 am »
are you sure smoke is coming from exhaust?? and not smoking form some other place? are you using plenty of cold flow for fuel?
« Last Edit: January 25, 2013, 04:02:12 am by air-cooled or diesel »
Reply #8January 25, 2013, 05:11:39 am
« Reply #8 on: January 25, 2013, 05:11:39 am »
I'd set the smoke issue aside for a moment and check the basics on starting/running:
I'd place a 12V test light on the GP buss and another on the fuel cutoff.
Clear lines to/from the IP. (If you have vinyl lines, they get stiff in the cold and can let in air at the barbs.)
If those check ok, but still hard to start:
I'd crack the hardline fittings at the injectors to verify fuel is reaching the injectors.
I'd bottle-feed* the IP to eliminate the tank/lines/filter as factors. (* lines to/from IP go to clean container by engine)
Could be compression, maybe leaking turbo seals dumping oil into the intake/exhaust. (would explain smoke - leaking onto exh. manifold) I'd check compression and look in the intake elbow for oil soaking.
I'd install a hose-heater in the bypass hose to warm engine - get through the season until a good time to re-ring or rebuild turbo.
Reply #9January 25, 2013, 05:49:00 pm
« Reply #9 on: January 25, 2013, 05:49:00 pm »
plenty of cold flow for fuel?!
what are you talking about?
Reply #10January 25, 2013, 05:53:23 pm
« Reply #10 on: January 25, 2013, 05:53:23 pm »
Have you changed any fuel lines anywhere lately?
have you checked the input shaft seal on the injection pump? pull the timing cover, and check that the pump shaft, pulley, and pump bracket are not wet..
are you positive that you dont have any air leaks in your fuel system?
air leaks will cause the engine to smoke at idle as well, because the pump cant make enough internal pressure to operate correctly..
Reply #11January 25, 2013, 08:34:13 pm
mtnbob
  • 738
« Reply #11 on: January 25, 2013, 08:34:13 pm »
I replaced all four glow plugs and I'm back and running. Not sure how I missed that, but they must have been slowly dying and I didn't notice.
Reply #12January 28, 2013, 08:29:30 am
« Reply #12 on: January 28, 2013, 08:29:30 am »
plenty of cold flow for fuel?!what are you talking about?
what im talking about he had cold start problems, seems he fixed it with glow plugs, cold flow could have been problem(fuel mixture for cold weather).
Reply #13January 28, 2013, 05:24:46 pm
« Reply #13 on: January 28, 2013, 05:24:46 pm »
Sometimes when the glow plug relay fails it will trigger the glow plugs on while driving which will burn out all four in short order unless they are duraterms.
Reply #14February 01, 2013, 12:47:25 pm
« Reply #14 on: February 01, 2013, 12:47:25 pm »
cold flow? There doesn't have to be ANY FUEL flowing, as long as the pump is full of fuel, and the injector lines are primed.
« Last Edit: February 28, 2013, 02:23:10 pm by 8v-of-fury »
