Author Topic: Intermitent slow/no starting New problem...  (Read 8811 times)
December 07, 2012, 12:59:28 pm
bbob203
  • 1789
« on: December 07, 2012, 12:59:28 pm »
Had this happen a few times recently. Don't want car catching on fire what should i look for wiring kills me....
« Last Edit: December 11, 2012, 06:47:27 pm by bbob203 »
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1December 07, 2012, 01:25:57 pm
Re: Intermitent slow/no starting smoke under dash
« Reply #1 on: December 07, 2012, 01:25:57 pm »
Yikes. GP relay short...
or possible headlight short. Watch out for that stupid cluster screw by the headlight switch. The screw's edge can short the unfused terminal on the switch.
Reply #2December 07, 2012, 01:57:08 pm
bbob203
  • 1789
« Reply #2 on: December 07, 2012, 01:57:08 pm »
i don't think its the gp system it happens after i've been trying to get it to crank when it wont just goes slow slow crank womp womp womp brrrrm then the smoke make sense? Also worth noting after an ip swap the other extened cranking was where this showed up also at one point the positive cable to the starter got hot and meltyish.
03 Jetta wagon TDi
Reply #3December 07, 2012, 02:39:15 pm
« Reply #3 on: December 07, 2012, 02:39:15 pm »
IIUC, you mean the smoke occurs after extended slow-crank and lite-off... I would still suspect the GP wiring - the post-glow energizes the buss for a few seconds.
If there has been repeated occurrences of smoke, things have likely gotten hot enough to leave visible evidence. No fun to go looking for trouble in an inconvenient location, but better than a fire.
Reply #4December 07, 2012, 04:31:30 pm
bbob203
  • 1789
« Reply #4 on: December 07, 2012, 04:31:30 pm »
I will head your warning of gp problems. :-\  But no when this problem occurs it wont start up the cranking just like dies then ill try again in a few minutes and it cranks over and fires up right away.
03 Jetta wagon TDi
Reply #5December 07, 2012, 08:15:58 pm
« Reply #5 on: December 07, 2012, 08:15:58 pm »
2 things....
1.)seat belt on door = relay so when buckled will start.. no buckle = no start...
it could be removed, jumpered... when wires break in door this cure..
2.)ignition switch dying could do that too..
Reply #6December 07, 2012, 08:18:31 pm
« Reply #6 on: December 07, 2012, 08:18:31 pm »
A short to the Glow plugs from the relay then.  There is a lot of juice headed out the firewall to the fuse.  Maybe there is a short as it exits the firewall but before the fuse.
This is why some of us choose to Pimp our glow plugs.  It puts all the big current stuff out from under the dash.  Right now you have a potential fire hazard.  I carry a 5 LB fire extinguisher with me.  Generally use em on someone elses car.  Like yours.
Another reason for the pimp I found today as I was removing the head is that all I have to do is pull the four wires at the external fusebox and I don't have to try and remove each wire from the ends of the gps. Saved me having to get behind the IP with the tiny 8 mm and loose the nut behind that whole mess.
Reply #7December 08, 2012, 02:43:50 am
bbob203
  • 1789
« Reply #7 on: December 08, 2012, 02:43:50 am »
I have my glows individually wired with 10 ga wire then to a fuse block. still need to add the e 350 solenoid I have. Seatbelt *** bypassed by po. bad ground somewhere messing up my starting circuit?
03 Jetta wagon TDi
Reply #8December 08, 2012, 05:18:48 am
« Reply #8 on: December 08, 2012, 05:18:48 am »
ignition switch I would guess
Reply #9December 08, 2012, 06:04:39 am
« Reply #9 on: December 08, 2012, 06:04:39 am »
nope... check po work... bet he has crappy splice on the wire that was crossed to bypass the relay!! that wire is the one that goes to the starter... comes from ignition switch..
Reply #10December 08, 2012, 06:10:22 am
« Reply #10 on: December 08, 2012, 06:10:22 am »
also to add on glowplug thoughts... no...
why...
factory system..
1.)glow plugs stay powered and on for a few sec after its running... so letting off key = plugs still have load.. why smoke now?
2.) that big red wire would cut/weld before it smokes..
upgraded...
unless you know what it is.. no idea.. but wold no cause a "slow start" so this also goes with factory system...
so cross that out...
Reply #11December 08, 2012, 06:36:50 am
bbob203
  • 1789
« Reply #11 on: December 08, 2012, 06:36:50 am »
the bypass is a wire from something in ignition switch to smaller wire on the starter.
edit: and its kinda ghetto how its spliced in. Casing stripped of about 3/8 of an inch section and wire wrapped around it and taped up.
« Last Edit: December 08, 2012, 07:49:18 am by bbob203 »
03 Jetta wagon TDi
Reply #12December 08, 2012, 06:12:59 pm
« Reply #12 on: December 08, 2012, 06:12:59 pm »
Reply #13December 11, 2012, 06:53:36 pm
bbob203
  • 1789
Re: Intermitent slow/no starting New problem...
« Reply #13 on: December 11, 2012, 06:53:36 pm »
New problem surfaced today. Drove my car around all morning came home for a few hours. Then I left for work at noon again no issues and home for lunch for a bit this is when I had the problem.. Get in hit the glow plugs real quick turn the key to start I get nothing and the digital clock went out when I turned the key when I released the key the clock came back but it had reset. Same thing happened second and third time and I just ditched it and drove my b3.  ???
03 Jetta wagon TDi
Reply #14December 11, 2012, 06:56:17 pm
« Reply #14 on: December 11, 2012, 06:56:17 pm »
Bad wire from the battery to the starter or to the engine ground, it could be a loose connection as well. A voltage drop test should show you where the issue is.
