Author Topic: Intermitent slow/no starting New problem...  (Read 9054 times)
Reply #15December 11, 2012, 07:18:27 pm
bbob203
  • 1789
Re: Intermitent slow/no starting New problem...
« Reply #15 on: December 11, 2012, 07:18:27 pm »
Just got home its as if my battery is totally dead as a door nail..
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #16December 11, 2012, 07:22:41 pm
bbob203
  • 1789
« Reply #16 on: December 11, 2012, 07:22:41 pm »
pardon the ignorance how does one perform a voltage drop test?
03 Jetta wagon TDi
Reply #17December 11, 2012, 07:28:26 pm
« Reply #17 on: December 11, 2012, 07:28:26 pm »
Recharge battery with external charger overnight.
Tomorrow, crank with a DMM black probe on the battery neg, use red probe on the other connections (starting with the battery pos) - see if/where it falls below 11V.
Bad connection to Batt or alt can fail to charge.
Reply #18December 11, 2012, 07:29:44 pm
« Reply #18 on: December 11, 2012, 07:29:44 pm »
Forgot to say disconnect the fuel cutoff to test cranking/voltage.
Reply #19December 11, 2012, 07:49:51 pm
« Reply #19 on: December 11, 2012, 07:49:51 pm »
If your battery is dead, you probably have something drawing some amps that shouldn't be so I'd look into that first
Voltage drop test how-to
http://www.vwdiesel.net/forum/index.php?topic=22321.0
Reply #20December 13, 2012, 08:27:39 pm
« Reply #20 on: December 13, 2012, 08:27:39 pm »
edit: and its kinda ghetto how its spliced in. Casing stripped of about 3/8 of an inch section and wire wrapped around it and taped up.
That is a legitimate wire splice, called a T-splice.
X3.8 on the voltage drop test.
Reply #21December 13, 2012, 09:09:06 pm
« Reply #21 on: December 13, 2012, 09:09:06 pm »
Also might be worth your while to hit the starter solenoid output terminal with a jumper cable.  if it pulls 500 amp, and still hardly cranks with no load, the starter is the problem.
Obviously be in neutral just in case.
Reply #22December 13, 2012, 09:32:37 pm
« Reply #22 on: December 13, 2012, 09:32:37 pm »
I have done a starter jump from the engine bay with the car in gear.. WOOWEE she jumps forward with a gut lurch when your leaning on the core support! lmao
Reply #23January 05, 2013, 02:07:27 am
bbob203
  • 1789
« Reply #23 on: January 05, 2013, 02:07:27 am »
can someone explain this starter jumper test deal better?
03 Jetta wagon TDi
Reply #24January 05, 2013, 06:27:09 am
« Reply #24 on: January 05, 2013, 06:27:09 am »
You can energize the starter by jumping +12 to the starter solenoid small terminal... but if the car is in gear, it can run u over.
Intermittent slow crank is usually poor connections, bad bushing, worn brushes/commutator.
Dead battery is usually bad connections, lose belt, old battery, persistent current draw (short, stuck relay).
Reply #25January 06, 2013, 05:39:06 pm
bbob203
  • 1789
« Reply #25 on: January 06, 2013, 05:39:06 pm »
Welp new battery, Big fat 2ga negative terminal grounded to the transmission bellhousing bolt. Tightened belts and Im firing off in half a crank. 1000ca 850cca battery group 34/78 dual terminal options on it. I think i may run a nice big wire from my alt to my battery via the positive side post.
I think my problem was a really wimpy ground causing bad voltage drop causing weak cranking and heating up wires all through the car.
As soon as i got it all hooked back up 1 cycle of the glowplugs no cs lever 34 degree it spun right up as if it hadn't been sitting lifeless for a month.
« Last Edit: January 06, 2013, 05:43:03 pm by bbob203 »
03 Jetta wagon TDi
Reply #26January 06, 2013, 06:05:40 pm
« Reply #26 on: January 06, 2013, 06:05:40 pm »
Love it, great success story! :) I too just got a 34/78 (1050CA 875CCA) and it spins the engine so DAMN fast.
My up and coming upgrades will also include;
  • Big gauge battery cables
  • Remove the starter and clean up the starter to trans mating surface
  • Big body to battery ground
  • Bigger gauge between alternator and battery (being that I have a 120A alternator.. it stands to pass quite the amount of current!)
  • An entire tube of die-electric grease ;)
