Can anyone give me any idea what this engine is. It's in a Caddy I'm looking at and the owner has no clue.
Turbo diesel. Most likely a 1.6 liter, but I can't tell for sure.
it has a turbo diesel pump on it, and a 1.6 or 1.5 litre cylinder head. Because of the way the picture is taken, I can't tell if it's hydraulic or solid lifter. The block can't be seen very well in the pics so I can't really tell you if it's a 1.6 block or a 1.5 block or something else. To tell if it's a turbo block I'd need the engine # off of it. For the cylinder head I'd need the casting # from it to tell you what it was. If it is a factory set up (ie if no one has been mixing and matching parts) then it is a 1.6 turbo diesel with either a solid lifter or hydraulic cylinder head. People do routinely mix and match engines and heads and injection pumps on these cars however so it is possible you may have a mixed combination of things there.
Further news---According to the owner, it's from a 1983 Jetta, so that prolly means solid lifter.
Is there a listing somewhere of the Engine/Block #s and Head Casting #s ??
The bottom of the block is marked 068 103 011 and this is the head. It was always my understanding that the hump between cylinders 2 and 3 designates a hydraylic engine, but this came out of an original 1983 Jetta (mechanical lifter)
Moved to General. Not IDI engine / power enhancement related.
