Author Topic: Toilet Bowl manifold differences?  (Read 5507 times)
November 03, 2012, 01:20:48 pm
monomer
  • 414
« on: November 03, 2012, 01:20:48 pm »
Having some issues here (as normal...)
Motor came out of a mk2 jetta. Manifolds looked the same, scrapped the other two I had laying about. Car's a mk1 rabbit.
Install the DP today. The clamps interfere with the shift lever (USRT kit) I can't for the life of me figure it out, besides the manifold being offset for a different chassis.
Unless I missed something, I'm about to track down a header and be done with it.
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #1November 03, 2012, 01:54:27 pm
monomer
  • 414
Re: Toilet Bowl manifold differences?
« Reply #1 on: November 03, 2012, 01:54:27 pm »
Pic:
www.michiganvw.org
Reply #2November 03, 2012, 07:31:16 pm
« Reply #2 on: November 03, 2012, 07:31:16 pm »
MK1 and MK2 have different downpipes.
Reply #3November 03, 2012, 07:41:53 pm
« Reply #3 on: November 03, 2012, 07:41:53 pm »
MK1 and MK2 have difference manifolds, and that's what's getting you.
MK2 exits behind cylinder #3, mk1 exits between cylinders 2 and 3
Reply #4November 03, 2012, 10:31:26 pm
  • 2926
« Reply #4 on: November 03, 2012, 10:31:26 pm »
 I don't have any experience with the MK1 TD exhaust manifold and didn't know it was any different than the MK2.
 I have seen the stock MK1 turbo outpipe, it sets the toilet farther to the right.
Reply #5November 03, 2012, 10:41:16 pm
monomer
  • 414
« Reply #5 on: November 03, 2012, 10:41:16 pm »
It's N/A.
I call it a downpipe...because it kinda is still. For future reference, It's drivers side of passengers side on a car, left and right just don't cut it (UK's excluded.)   :-X
This is what I get for having a bunch of random vw parts laying around, it's been four years since this car's been together.  :-[
I'm just going to slap a header on it and be done. With this setup I'd be looking at fabbing up a test pipe, as the autotech exhaust I have is cat back, and the cat is long gone. Besides, how many diesels have you heard with a downpipe and decent exhaust?
www.michiganvw.org
Reply #6November 04, 2012, 09:39:22 am
« Reply #6 on: November 04, 2012, 09:39:22 am »
It's N/A.
the header is gonna hit the steering rack unless you buy an EXPENSIVE header..
Reply #7November 04, 2012, 09:52:43 am
« Reply #7 on: November 04, 2012, 09:52:43 am »
are you sure your shift linkage is set correctly? I have a missing linkz kit and it doesn't come that close to the block...MK2 but still.
Reply #8November 04, 2012, 09:58:39 am
« Reply #8 on: November 04, 2012, 09:58:39 am »
mk2 manifold in a mk1 is the problem...
im sure the shifter is correct.
Reply #9November 04, 2012, 11:09:25 am
monomer
  • 414
« Reply #9 on: November 04, 2012, 11:09:25 am »
A raceland or obx header wont work?
It shifted...fine.
www.michiganvw.org
Reply #10November 04, 2012, 08:48:06 pm
« Reply #10 on: November 04, 2012, 08:48:06 pm »
One off a Scirocco or 8v GTI would probably suffice (header)
Reply #11November 04, 2012, 09:57:39 pm
mystery3
  • 774
« Reply #11 on: November 04, 2012, 09:57:39 pm »
It shifted...fine.
I had a cheapo header that I picked up with some other parts and ran it for a while on a mkI with no problems. Car had a "short shifter" consisting of a chromed shift lever with extra holes I found at the junkyard. I think a raceland/obx/ebay header should work fine as long as it's made for mkI.
Reply #12November 05, 2012, 10:46:54 am
« Reply #12 on: November 05, 2012, 10:46:54 am »
It shifted...fine.
i was speaking of the pace setter headers..
either way tho, if you dont brace the hell out of it, the diesel will just vibrate it to bits..
my header vibrated off the studs a few times on my diesel.. finally made a brace from the block to the collector..
stayed put after that.
Reply #13November 05, 2012, 07:06:38 pm
hillfolk'r
  • 1532
« Reply #13 on: November 05, 2012, 07:06:38 pm »
It's N/A.
Ya can make em sound great,the na's that is..im runnin a 2.25 inch homemade exhaust from the dp back with just a 12 inch long summit glasspack.
total cost,90$...
next hat trick is to remove the stock dp and make it like 2.25 to match the system.
its probably wirth 2.63 hp at 4193 rpms,and as much as 2.81 hp at 5276 rpms by my calculations that my butt dyno has extracted....
Ah who am i kiddin? Any power increase definitely came from the dtm tip
Throttle cables ftw
