FS: used working t3 turbo - Parts for Sale/Wanted - VWDiesel.net The IDI, TDI, and mTDI source.
bydamacon 18 Oct, 2012 14:21
I yanked this off the car I have been driving a while. Seems to do the job just like the others I have had with stock fueling/blowoff valve settings. Just bare turbo, no drain line like pictures below. This sucker was leaking like crazy with that drain line. Also I think the fitting on the bottom of the turbo needs attention because of leaks. When I put it back in service I just used what was there, a little piece of rubber jammed into metal pipe through the turbo hole with a dab of rtv and it didn't hold up. I have seen some people tap that hole with a fitting which makes sense. The turbo I have on my latest engine has done the same.
When looking at the turbo inlet I can't tell if somebody painted the fins? Looks like some black is flaking off and there is buildup that should be cleaned up.
