Author Topic: Is anyone a machinist?  (Read 3450 times)
August 14, 2012, 07:10:16 pm
bbob203
  • 1789
« on: August 14, 2012, 07:10:16 pm »
I screwed up the sleeve bearing on my trans that's inside the selector housing that the selector shaft rides on. My idea here is to machine some brass or heavy duty plastic to replace the bearing. Thoughts? Could anyone make these?
92 Passat wagon M-TDi
03 Jetta wagon TDi
VE Timing tools for rent
Reply #1August 15, 2012, 01:14:09 pm
slowcaddydan
  • 20
Re: Is anyone a machinist?
« Reply #1 on: August 15, 2012, 01:14:09 pm »
try robert, the guy who makes the intermediate shaft bearing removal/replacement tools?
rdezsofi on vwvortex. i think he's on here too.
Reply #2August 18, 2012, 12:06:40 am
« Reply #2 on: August 18, 2012, 12:06:40 am »
I'm sure it could be done. But the cost of a used 020 trans is low enough that I would be hesitant to spend money on custom-made parts.
Reply #3August 19, 2012, 07:27:53 am
monomer
  • 414
« Reply #3 on: August 19, 2012, 07:27:53 am »
Put your location in your profile.
I'm a machinist. A used 020 would be cheaper....
-1983 Rabbit LX 1.6/1.9 VNT build
Michigan Volkswagen Enthusiasts
www.michiganvw.org
Reply #4August 19, 2012, 09:51:03 am
bbob203
  • 1789
« Reply #4 on: August 19, 2012, 09:51:03 am »
I ended up getting the sleeve bearing thru the dealer for 13.50 tapped it out with an 18mm socket perfect diameter to tap it out with.
03 Jetta wagon TDi
