if the CCV ports are plugged in the intake, it doesnt matter what you do, short of venting to the atmosphere, will never fix your puking oil problem..
end of story..
For the intake use a gasser manifold, preferably the one from the g60 corrado and an adaptor like this: http://www.bahnbrenner.com/vw_audi/products/1949/MkII_T_Body_Adaptor_to_3
or diy and then plumb from there. I like to use junkyard intercooler tubes and such because they're cheap and you can find bends that fit nicely.
why do you need a gasser intake on a n/a? that COMPLETELY gets rid of the CCV ports..
i never thought it would be worth it to add a gasser intake to a n/a...
DID YOU SPRAY WD-40 DOWN THE INTAKE CCV PORTS!?
The g60 manifold has more ports than I know what to do with. I setup a g60 hockey puck on top of the g60 valve cover and it's good to go.
The runners are bigger and it's way cleaner to build an intake from as opposed to chopping the stock airbox and gluing some abs down over the middle of the engine. This way you can put the filter in the raintray, by the battery tray or anywhere.
That'd be like saying adding intake piping for a cold air pickup would loose low end torque? Because adding piping is effectively lengthening each runner by however much pipe you add.. For me, nearly 3 feet.
Like this engine.
no..... just cleaned out the one on the valve cover.
What CCV holes in the intake manifold are you talking about? The drain holes to evacuate oil or whatever into each intake runner? How in the world do you expect that them getting clogged up would effect crankcase ventilation? The oil vapor is is going into the runners at the top of the intake not those little drain holes. They just get rid of puddled oil in the bottom of the manifold.
