The pumps will be completely dissembled, resealed using 100% genuine OEM Bosch DGK 126 kits, cleaned up and setup to within original stock settings. I will also adjust the pressure regulator for proper dynamic advance. Each pump needs small fine adjustments to run properly on your engine as each one is completely different in adjustments needed. Also note this is not a rebuilt pump, this is merely a resealing service for the time being. Everything that I take out of the pump I put back in, nothing new. These are sold as-is, my time is non-refundable.
I offer an affordable service of resealing pumps you already have as well. I have experience in all Volkswagen VE pumps(1.5, 1.6NA/TD, 1.9AAZ, and 1.9TDI), 2.5 Land Rover pumps, and 505 Peugeot pumps. You pay shipping both ways, the cost of the seal kit, and a couple hours of my time. Although I have not had any actual experience with the Cummins Bosch pumps I am fairly confident I can reseal them too.
The pictures in this thread are my own pictures that directly reflect my work done. ___________________________________________________________________________________________________________________
NOTE: The red date below is my current stock November 4th 20131 - 1.6 TD pump
3 - 1.6 NA pumps
1- 1.9 TDI AHU parts pump
TONS OF RESEAL KITS!
PM ME FOR MORE DETAILS _________________________________________________________________________________
Land Rover Discovery 300TDI pump, for my M-TDI. Polished.ONLY BOSCH GENUINE SEAL KITS 1.9 AHU, fully functional electronics. You get what is pictured. Vane pump is good, and it has a new shaft seal in case. This pump made proper pressures when it ran.
FOR SALE $150 USD + shipping
