Author Topic: New 82 Vanagon Diesel, ran out of fuel.. issues arised.  (Read 28917 times)
Reply #90November 27, 2011, 07:40:29 pm
steevz
  • 229
Re: New 82 Vanagon Diesel, ran out of fuel.. issues arised.
« Reply #90 on: November 27, 2011, 07:40:29 pm »
Backed the screw out a whole bunch and shes runnin now.
Reply #91November 27, 2011, 08:56:24 pm
« Reply #91 on: November 27, 2011, 08:56:24 pm »
drive it but don't break it.  Report how it runs.
Reply #92November 27, 2011, 11:49:41 pm
steevz
  • 229
« Reply #92 on: November 27, 2011, 11:49:41 pm »
Its runs great while driving. Not a powerhouse... but 100x more power then last time I "drove" it. All my exhaust studs snapped while removing the bolts.. inside the exhaust manifold.. I tried drilling them out but even almost whole size the left over bits won't come out.. any way to do this? Drill all the way and tap add bigger studs?
IdeaS?
Reply #93November 28, 2011, 06:38:56 am
« Reply #93 on: November 28, 2011, 06:38:56 am »
lots of penetrating oil soaking on it, heat the exhaust manifold some with a torch to expand the metal but don't heat the bolt areas.  I have had good luck using easy outs for this problem.
Reply #94November 28, 2011, 10:56:06 am
Toby
  • 728
« Reply #94 on: November 28, 2011, 10:56:06 am »
Easy-out suck because if the bolt does not want to come out they will swedge what is left into the hole if you use the size they call for, so you must use and undersized one not to risk making it all but impossible to get out.
If you have the hole drilled to the point where you can see the threads from inside the hole you can usually pick out the remnants of the bolt with a sharp pick. If not, which is likely, because it is quite hard to get the hole in the bolt both concentric and right down the centerline of the bolt for its entire length, you will need to use a tiny diamond point chisel to collapse the remnant of the bolt in on itself. You can then grab the remnant with small needle nose pliers and spin it out. This will bugger the threads a bit, but it cannot be helped. Just clean them up with a DULL tap or a thread chased.
One thing to remember is that candle wax melted into the hot part will often wick itself into the threads and free the remnant of the bolt. I like to follow this with a very sharp, narrow center punch and a small ball peen. Make a small center punch prick at the edge of the broken bolt. Then make it deeper and work the bolt with the punch held tangential to circumference of the bolt to unscrew it. You may have to move 180* around the bolt and take another bite as the bolt may bind in the hole.  If you can find any kind of ridge on the face of the break in the bolt, use that to get a better "purchase" when striking the punch with the hammer. This is delicate work  and usually not very quick, so try not to be ham handed or you will just make it worse.
Reply #95November 28, 2011, 11:52:34 am
steevz
  • 229
« Reply #95 on: November 28, 2011, 11:52:34 am »
Oh yeah, its also not smoking anymore.
Reply #96November 28, 2011, 12:16:07 pm
« Reply #96 on: November 28, 2011, 12:16:07 pm »
What is the chant?  If you don't have pictures it didn't happen?  Another video of proof please.
Reply #97November 28, 2011, 08:11:28 pm
« Reply #97 on: November 28, 2011, 08:11:28 pm »
Definitely shoot some more video!!  :D
Reply #98November 28, 2011, 08:14:09 pm
steevz
  • 229
« Reply #98 on: November 28, 2011, 08:14:09 pm »
Going to run some diesel purge through it tonight when I get home from work. Tomorrow morning ill take video.
Reply #99November 28, 2011, 08:34:49 pm
« Reply #99 on: November 28, 2011, 08:34:49 pm »
Oh not that line, I will ____ in the morning.  Going for the fog effect, or the cold start success I guess.
Reply #100November 29, 2011, 01:35:50 am
steevz
  • 229
« Reply #100 on: November 29, 2011, 01:35:50 am »
Lol, no I work from 3pm - 1am. So, it's dark when I get home, no good for taking video.
Reply #101November 29, 2011, 10:11:24 am
Mark(The Miser)UK
  • 1557
« Reply #101 on: November 29, 2011, 10:11:24 am »
What I have done is MIG a lump onto the piece of stud. Enough to grab with vice grips. If there is any protrusion, then MIG a nut on. This extreme heat often loosens the stud  somewhat.
Mark-The-Miser-UK
Reply #102November 29, 2011, 11:06:48 am
steevz
  • 229
« Reply #102 on: November 29, 2011, 11:06:48 am »
Okay, cold start video of the Vanagon this morning.
http://www.youtube.com/watch?v=2NjhyAuIYEU
Didn't do the diesel purge yet. Going to do that now. That's without using the block heater too, which actually functions amazingly.
« Last Edit: November 29, 2011, 11:30:56 am by steevz »
Reply #103November 29, 2011, 12:10:04 pm
« Reply #103 on: November 29, 2011, 12:10:04 pm »
BTW the god-awful rattle is the mostly-not-attached exhaust system... :)
Glad to see how much cleaner it's running - that looks better than after we got it going for sure.
Reply #104December 02, 2011, 05:51:11 pm
steevz
  • 229
« Reply #104 on: December 02, 2011, 05:51:11 pm »
How.. changed the front brake pads and bled the brakes today. Big clonky calipers.. 1 piece, 2 pistons. On the passenger side it had a seized piston and that brake pad was bare metal on metal, the rotor was pooched too.
Got the piston freed up, bled again and now no more grinding. :)
« Last Edit: December 02, 2011, 10:19:09 pm by steevz »
