TDI Engine -General Info
Delivery valve mods
Topic: Delivery valve mods (Read 6073 times)
February 02, 2006, 02:57:17 pm
therabbittree
Delivery valve mods
February 02, 2006, 02:57:17 pm »
Ok I did the vw governor swap on the "new" 4bt pump..i did the govenor mod too.... I am debating modding the delivery valves too..cutting them for more flow..I opened this pump up and checke dout teh cam plate i wrote th e#s down,,it is in the garage now I will post later but the ramps were pretty steep and tall.....any way I think I'm gonna keep the Longer Cuymmins DI delivery valves and i may cut tehm like my dodges laser cut ones..i have two sets of long DI cummins valves here so if its too much i will change it....I hope this pump provided the nut i need ..argh the outher pump just isn't doing it..mummn i wonder if its because i have IDI delivery valves on th mech tdi?..that might be the problem?..any how that pump is being changed out ..
any info or tips..? I did a search and the only Delivery valve sstuff was IDI guys trying DI valves out etc...
Later
Deo
February 02, 2006, 07:31:21 pm
therabbittree
Delivery valve mods
February 02, 2006, 07:31:21 pm »
well i cut the crap out of a set and they are mounted in the pump..i have a set of stockers too so if it doesn't work out then out they go.. i hope this pump works liek joes is saying..if so i think i may have to build a set of twins to cool the egts..down..ha..we'll see
Later
Deo
February 02, 2006, 08:42:51 pm
hillfolk'r
Delivery valve mods
February 02, 2006, 08:42:51 pm »
hey deo i jus remembered,,they gave me all new delivery valves in it when they put the big head on it,,i wonder if they are correct,,ill haveta ask,,what do i need to do, put the correct delivery valves in for a tdi??
Throttle cables ftw
February 03, 2006, 05:52:57 am
therabbittree
Delivery valve mods
February 03, 2006, 05:52:57 am »
i guess tell them the old engine was idi... your new one is a DI.. so you need the DI d- Valves and if they can make sure the Pressure is high.. as teh hybrid pump of mine ..well you saw it..it rocked ona idi..but doesn't do any thing with the TDI..i'm hoping the CUMMINS 4bt DI pump i just modified will work good...i hope.. i swapped th eother cummins pump top with teh fuel shut down lever..swapped the vw throttle sahft bushing and the vw throttle shaft and teh vw governor..i removed the intermediate shaft and shimmed it so it is solid there..then left the main spring alone but added a small washer unthe the main shaft retaining circlip so it preloaded th emain shaft a hair on its retainer...i hope that works good..i also swapped in my old fuel screw with the lock cut off , i used the thinest big fuel pin ..in fact the stock one from that pump was nice..i lowered the spring seat all the way down..used a thinner nylon washer, and a custom heated up and squeezed pin spring, i also swaped vw lda cover so its easy to set the fuel pin preload etc.. ..its set on kill right now besides the idle and fuel screw..so if this pump won't work then i'm fit to be tyed...argh..i ground these d valves eal thina dn lapped them to there seats with valve grinding compound..so it should be sweet..
later
Deo
November 29, 2006, 01:34:56 pm
Holeshot
User+
Delivery valve mods
November 29, 2006, 01:34:56 pm »
Deo,
How did the cut DV's work out?
Later,
Matt
'94 Dodge Ram 2500 4x4 - 12-valve Cummins, NV5600 6spd, SBC Con FE clutch, EDM injectors, etc. ~400rwhp, Isspro EGT/100psi boost gauges
'98 VW NB TDI - not stock by any means, but still pretty tame. TDI-M candidate :cool:
'00 VW Jetta TDI - wife's 300,000+mi daily driver
November 29, 2006, 03:48:32 pm
therabbittree
Delivery valve mods
November 29, 2006, 03:48:32 pm »
well I nicked one, and never installed the set..argh so I never tried them out.... kinda sucked ..the dremel slipped argh ..I hope to try another set or figure out a different way ..or send them out ..is this Amero talking or what ?
Thanks,
Deo
November 30, 2006, 12:10:51 pm
Holeshot
User+
Delivery valve mods
November 30, 2006, 12:10:51 pm »
Quote from: therabbittree
...this Amero talking or what ?
Yup.
Crap. I was hoping that you'd get a chance to try out modified DV's with a VE pump... If I didn't have to drive my TDI everyday, I'd hack the DV's in my VP-37 and then watch it stumble like a SOB like it does already...haha
Matt
Delivery valve mods
