or will it not spool correctly since its a gasser turbo? ive heard gasser turbos dont spool up the same as diesel turbos..
that was a BIG T3 off a 2.5L engine.. it would have been horrible on a diesel.
im talking about a wee little T2 is all.. its off a similarly sized (1.8L) engine also. much closer in size than a 1.6 and a 2.5
but it doesnt even matter, the T2 is going on my 86 GTI. i re-drilled the flange on a stock single downpipe manifold to fit the turbo.
i have all the bits needed to convert CIS-Lambda to be boost friendly also.. so all i need to do is put all of it together, and get it running.
its gonna be sweet having 2 BOOSTED CARS!
that big turbo is on that 1.6 diesel now and spools just fine even tho its a gas turbo and wont work. from my experiance the stock turbo thats on the sr20det is rather small but that engine flows extremely well and revs very high.
the 2.5 engine had a mitsu turbo which is just a hair smaller than a t3 is and 2.2 came with a decent sized t3. the super 60 is what i would call a large t3. the mitsu im using has some lag yes but im using a large front mount. i will have a video of it not spooling up at all soon.
the size of the displacement is not so relavent. the 2.2 and 2.5 share the same head and everything only difference is the 2.5 has more stroke. the mitsubishi was put on the 2.5 for basically instant spool. faster than the vnts that were on the 2.2s in fact and were out of breath by the time 4 grand came around.
the best thing about the bigger gas turbos turbine side is the lower egts i seem to be seeing at around 20 pounds of boost.
look at the compressor map. nothing else.
thats why i run around 15 usually. it seems to just be working great around then tho. i might try it higher if i get gutsy. i might put the garrett on the car if i get bored sometime since i know its good up into the 20s.
the sr20 is the one most people run because they ditch the CA18. my friend had one make over 500 horsepower to the wheels. my point is that they flow alot of air and rev very high.
im actually running the front mount off his old car on the rabbit right now.
that turbo will probably work great for what your looking to do be really torqey down low and have no top end.
im honestly glad that you proved me wrong.. it means i have more useable turbos for my diesel.. sorry i was being a nay-sayer the whole time.. i was just going by what someone (who i thought knew what they were talking about) had told me about putting gasser turbos on a diesel engine.. im glad it indeed DOES work tho..
but, im not talking about SR20s, or CA18s or anything like that.. im simply talking about the turbo off a CA18.. i have it in my possession, and its bolted to an 8v VW exhaust manifold.. thats cool that the SR20 turbo is small, and can keep up with HIGH rpms..
and what do you mean about the turbo having no top end? im not going to be spinning the engine past the stock red line anyways..
are you saying that its gonna run out of breath before the rev limiter?
sr20 and ca18 had similar turbos, it really depends what ca18 it came from tho
either way id go with a slightly bigger turbo i would think. depends if you make the top end flow any better i guess.
