#15
by
Grey_Smoke
on 28 Aug, 2011 23:10
ok, What do I do?
The Bentley I have access to has a pic of a box that is says is for a 85 to 89, and the front looks the same so I didn't know anything was wrong.
#16
by
on 29 Aug, 2011 10:33
your car should have relays on one panel, under the dash. and it should have fuses on another panel, mounted to the dash, with an access door above the gas pedal and beside the center console..
89 or 90, VW made a switch, from CE1, to CE2 wiring.. CE2 had 1 fuse/relay box.. CE1 had 2, one for fuses, and one for relays..
#17
by
vanagonturbo
on 29 Aug, 2011 10:34
That is NOT a CE2 fusebox.
CE1:
CE2:
#18
by
on 29 Aug, 2011 10:36
CE1 fuse boxes are 2 parts tho.. in the mk2 cars..
#19
by
vanagonturbo
on 29 Aug, 2011 10:38
No. You are thinking of Murrican made Golf wiring which has the fusepanel separate from the relay panel. I dont even know what the term is to describe the Golf wiring other than junk.
OPs car is CE1.
#20
by
on 29 Aug, 2011 10:52
OPs car is CE1.
...ive had lots of these "JUNK" wiring systems, and out of all the VW setups, i like this one best.. its been hands down the least troublesome wiring out of everything ive owned..
plus, you dont have to be a contortionist to check the fuses..
anyways, i was wrong.. sorry.. every fuse box ive ever seen like that, was a CE2 box.. hell, Nathan even thought it was CE2..
#21
by
vanagonturbo
on 29 Aug, 2011 11:12
You must work on a lot Golfs
Jettas and German made Golfs have a panel that pops out to check the fuses
#22
by
on 29 Aug, 2011 11:16
Wolfy cars are hard to find here, for some reason.. all i find are 1 cars (usa built) and 3 cars (mexico/brazil built) the W cars are quite scarce..
im familiar with the pop out panel. but still, its under the dash, and its screwed and clipped in. so you still have to be a contortionist to get to the panel and pop it out..
#23
by
vanagonturbo
on 29 Aug, 2011 11:24
Lots of 1 cars out here for sure.
3 cars should all have the popout panel. Its not held in with screws or anything, it just pops out.
1 cars are the ones with the long panel that goes behind the center console, but that doesnt really matter cause the fusebox is right there on teh early ones.
90-92 cars all had kneebars so thats where contortionism comes into play. For a 3 year run out of 8 years there are more easy access fuseboxes than there are contortionist fuseboxes.
Anyway, I think we are getting sideways here. I havent read all the updated info on this thread yet, so I will go back and read it.
#24
by
on 29 Aug, 2011 11:32
long panel behind the center console?
on what sort of cars? all my separated fuse panel/relay panel cars the relay panel was in the stock fuse box location.. not behind the center console.
and yes, i agree, we did get side-tracked a bit, now its back to the original topic..
#25
by
vanagonturbo
on 29 Aug, 2011 11:37
I was meaning the panel that holds the fusebox goes from one side of the car to the other on the 1 cars, but the w cars have two separate pieces that screw into the side of the center console.
Yes, so back on topic. OP, are you certain your test light works?
#26
by
on 29 Aug, 2011 11:44
oh, yes, gotcha.. that whole panel that has cubbys that sits where a knee bar would be..
yea, check your test light on the battery.. ive had problems that turned out to be my test light had a bad bulb. fixed the bulb and then i could trace the right wires..
#27
by
Grey_Smoke
on 31 Aug, 2011 13:12
I checked the test light a number of times as I was using it, just to be sure, and it works. I also used two different test lights.
*edit; oops
the test light works, but I didn't have it grounded properly, so there is power all the way to the relay, and despite trying three different relays, none of them work?
#28
by
vanagonturbo
on 31 Aug, 2011 15:36
did you ground the temp sensor at the coolant flange to see if it would turn the relay on?
#29
by
Grey_Smoke
on 31 Aug, 2011 17:24
not after I had the test light working properly, I will go try that now.
