02 Golf has a rattle where the top bolt of the tensioner shock goes through.
I can hush it up with medium fingertip pressure.
Anyone fixed this without buying a tensioner assembly?
Mine does the exact same thing, and ive checked to make sure the bolt is tight. Must be the design. Oh and it is a new tensioner.
I'm not sure that's what I wanted to hear
But I suppose I can hold off on buying another.
its a diesel shes supposed to have some rattles
did you try to just remove the shock. They leak and end up useless. The real problem is if the spring is soft, and not keeping enough tension on the belt. Not as critical as on an AAZ, but can still damage the crank if left for a long time.
