Author Topic: AAZ passat transmission question  (Read 4670 times)
Reply #15July 08, 2012, 09:19:27 pm
Big Daddy Roth
  • 298
Re: AAZ passat transmission question
« Reply #15 on: July 08, 2012, 09:19:27 pm »
my 93 AAZ B3 had a CHA
CTN is TDI only
1993 TD B3 Sedan
1992 G60 Syncro B3 Sedan
Reply #16July 12, 2012, 11:42:54 am
rodpaslow
  • 670
« Reply #16 on: July 12, 2012, 11:42:54 am »
I second that - i finally looked at mine pulled from a 93 passat and it's a CHA as well.
looking at the gearing, what is the chance of getting a used final drive gearing from a corrado or vr6 and certan gasser passat 02a?  Would be nice to drop the rpms a bit.  I want to pull mine apart and redo anything that needs it before I use it, be nice to change the ring gear at that time if I can fine one that's not out of this world $$ wise.
99' 1.9 1Z Tdi, hybrid pump -1.9 housing & rover internals, 2052 wastegate turbo,.25 hflox nozzles, SDI intake, CTN tranny
96' 1.6 TD Golf, Giles pump, VNT 17, Gas changed to Diesel, Air to Water Int.
