#15
by
ilikevwdiesel
on 20 Jan, 2011 17:15
#16
by
catlin_cava
on 20 Jan, 2011 17:53
If the car is free...Yes...and July and January both Start with J
#17
by
ilikevwdiesel
on 20 Jan, 2011 18:04
you can have it for free you peckerhead but the delivery charge is 500.
#18
by
on 21 Jan, 2011 01:01
Remember folks, the '84 has the plastic fender liners, the leaf screen over the hood vents, the plastic windshield surrounds, 3-bolt sun visors, the front bumper with gap cover, 100mph speedo, probably other things I forgot,.. most of which can only be found on the '84,.. some only on the '83/'84 Rabbits.
The '84 Rabbit is my favorite.
Bolt-through-wings?
What trany does it have?
#19
by
ilikevwdiesel
on 21 Jan, 2011 02:11
It does have bolt thru wing windows but the rubber is kinda dried out unfortunately. it's a 4 spd trans don't know the code.
#20
by
catlin_cava
on 21 Jan, 2011 03:21
Hows the Floor in the shell? I'm actually interested in the rolling chassis, Ill Give you an AAZ and trans for it
#21
by
ilikevwdiesel
on 21 Jan, 2011 06:52
I'd gladly trade you but I can't bring it way up there, not this time of year. I could meet you on the border that's it. You're just trolling me anyways cut it out you cyber bully.
#22
by
catlin_cava
on 21 Jan, 2011 08:50
I'm not being a cyber bully, Keep it till the spring and bring it up. Ill go AAZ AND AND AAZ shortblock also. I have no way of transporting it acorss the border
#23
by
ilikevwdiesel
on 21 Jan, 2011 08:59
you can drive it across if you do the paperwork before I show up with it.
#24
by
on 21 Jan, 2011 09:30
does it turn 4000 in 4th gear at 60mph?
or 2000 in 4th at 60mph?
the low geared trans is a GC usually, and the higher geared one is gonna be a GL or a 4A most likely.
#25
by
ilikevwdiesel
on 21 Jan, 2011 09:41
I don't know it doesn't have a tach but I'm pretty sure it's the tall geared one cause it will cruise at 70 on the interstate. The flat part lol. I'd go out and look but the snow is piliing up and the ground is frozen solid. I'm not 20 yrs old anymore that's for sure.
#26
by
on 21 Jan, 2011 20:10
Probably the 4A trany.
Seems like Ashleyroe has one, it needs a special reverse switch compared to others but is a great trany.
Was I right on the 100mph speedo?
If so,.. how much?
#27
by
mystery3
on 21 Jan, 2011 23:20
I'm interested in the thermostat housing assuming it's aluminum and the coolant flange on the front of the head if it has a big port 22x1.5 on it, I think it should being and factory a/c car. LMK
#28
by
ilikevwdiesel
on 28 Jan, 2011 18:08
#29
by
catlin_cava
on 28 Jan, 2011 19:58
