Can anyone tell me where the relay is located. Mine actually stopped doing it, so maybe it was just fluke and got wet or something, but I'd like to know so I can replace it if needed. Thanks.
My car is quite a bit older than yours but I had a similar problem..... I'd be driving along and the wipers would come on all by themselves for 2 or 3 swipes and then shut off. They always worked fine when I would activate them with the switch though. My original thought was the same as yours, switch or relay, but it ended up being the fuse box. I think what happened is water got in through the worn out grommet for the antenna lead and dripped into the fuse box and caused some electrical mischief on that circuit board inside. Replacing the box cured some other elctrical weirdness I was having in addition to that, but new fuse boxes are a bit on the spendy side so hopefully that's not the problem.
