Author Topic: Wipers are Staying on all the Time  (Read 5434 times)
January 08, 2011, 12:25:07 pm
Doakster
  • 291
« on: January 08, 2011, 12:25:07 pm »
Funny thing happened today. My wipers all of a sudden decided they won't shut of, I can control Hi/Lo speed but can not shut them off or go into intermittent.
Any thoughts on what would cause this..a stuck relay? Bad switch?
1991 VW Jetta 1.6TD (Formally an ECO), Giles LDA Pump and Injectors, Techtonics 2.25" Down Pipe and Exhaust system, Rebuilt Trans with 3.94 final drive and a Peloquin Limited Slip Diff, Front H&R Sport Springs, MK4 VR6/1.8T front brakes, Single Round Headlight Conversion.
Reply #1January 08, 2011, 12:29:51 pm
Wayland
  • 364
Re: Wipers are Staying on all the Time
« Reply #1 on: January 08, 2011, 12:29:51 pm »
When mine did this it was the relay.
84 Grumman Olsen Kubvan
93 Dodge CTD Truck
Reply #2January 09, 2011, 07:16:04 am
ricosuave
  • 244
« Reply #2 on: January 09, 2011, 07:16:04 am »
x2 for the relay, did it in my old mk3 jetta...
Reply #3January 09, 2011, 10:06:46 am
« Reply #3 on: January 09, 2011, 10:06:46 am »
x3 on the relay..
mk2 GTI, got a wet relay, pulled the relay, dried it out, put it back in and worked till i wrecked the car. i believe they were on when i wrecked it..
Reply #4January 09, 2011, 07:03:22 pm
Doakster
  • 291
« Reply #4 on: January 09, 2011, 07:03:22 pm »
Can anyone tell me where the relay is located. Mine actually stopped doing it, so maybe it was just fluke and got wet or something, but I'd like to know so I can replace it if needed. Thanks.
Reply #5January 10, 2011, 08:24:47 am
« Reply #5 on: January 10, 2011, 08:24:47 am »
most likely it just got a piece of moisture somewhere.. and it probably will never do it again as long as you own the car.
on my car, its the top left relay, but i drive an 85 with separate fuse panel and relay panel..
Reply #6January 11, 2011, 11:36:53 pm
Rabbit79
  • 196
    Burns, Oregon,USA
« Reply #6 on: January 11, 2011, 11:36:53 pm »
My car is quite a bit older than yours but I had a similar problem..... I'd be driving along and the wipers would come on all by themselves for 2 or 3 swipes and then shut off. They always worked fine when I would activate them with the switch though. My original thought was the same as yours, switch or relay, but it ended up being the fuse box. I think what happened is water got in through the worn out grommet for the antenna lead and dripped into the fuse box and caused some electrical mischief on that circuit board inside. Replacing the box cured some other elctrical weirdness I was having in addition to that, but new fuse boxes are a bit on the spendy side so hopefully that's not the problem.
Current: 1979 Rabbit 4dr
            1984 F-250
            1999 Ford Ranger
Other v-dubs I've owned:
84 Rabbit
78 Rabbit (gasoline) flipped it end over end after driving all night and falling asleep at the wheel. RIP, it was a good little car.
70 Bug
Reply #7January 14, 2011, 03:38:54 pm
Doakster
  • 291
« Reply #7 on: January 14, 2011, 03:38:54 pm »
It hasn't happened since, I don't drive the car all that much, right now it's just sitting in the yard, and I fire it up and move it when I need to clear snow, so who knows maybe it will never happen again.
Anyone know where the wiper relay is located??
Reply #8January 15, 2011, 11:36:41 am
« Reply #8 on: January 15, 2011, 11:36:41 am »
in my cars, its the top left hand corner of the relay panel..
