-1.6 Turbo Diesel block and hydraulic head which has been split. probably will need rebuild. this motor was imported from canada. MF is the block code. $400.
-also have several injection pumps available if you need cores as i do not know if they work. $100 for n/a $150 for turbo.
-also stripped an eco jetta. diesel fuel tank, wiring harness, fuel lines, body parts, ect.
no pics at the moment as I'm out of state.
location just outside of st. louis
400 bucks is a bit steep for a long block that needs a rebuild..
copy that.. I'm not sure if it needs a rebuild or not. maybe just rings, I really have no clue.
figured i needed to start somewhere. price is negotiable!
Do you have the intake and exhaust manifolds, along with oil lines and snorkle and air cleaner from the Eco engine?
Might very well have an interest.
I'm running the eco motor in my caddy. everything is being used with the exception of the air cleaner box. However, I might have a spare intake w/bov that is super clean and the turbo manifold. I'll have to check once i return home
Is it a CE1 or CE2 harness?
Also is the harness complete and in good shape? Will it come with the fuse panel and cluster?
Still looking for info on that harness. Thanks
I'm looking for a waterpump pully.
Got one that was relly bent up, but looks like the right size.
Part # is 068 121 037L
nearly 4 1/2" diameter
lip sits 1/4" off the surface when center is on table.
