I got on craigslist and found 3 injector testers.
One was a bosch,.. the plastic resevoir was missing,.. and I think it had a bad o-ring.
The resevoir on one of these cost $250 new so I found a properly threaded plug at NAPA and drilled it 1.8" NPT so I could put a Rabbit filter with the top cut off as a resevoir.
Last time I used it, I couldn't figure out how to release pressure when done.
A Kent-moore, which is nice compact and easily portable
Nice thing about the kent-moore is the knob that reduces pulses on the gauge.
It comes apart and is real easy to work on,.. replaced an o-ring
the third tester was for gas injectors,.. and had a bad resevoir too.
Got all three for $60,.. and a ride to the cities.
Here's the one I built:
It doesn't have a valve that allows me to lock the pressure and wait for drips, like the other 2.
It is more accurate for setting breaking pressures, but I usually test injectors with the kent-moore.
