Downpipe again
by
zaprzal
on 29 Dec, 2005 02:11
I have golf A2 GTD with SB engine (intercooled and 80HP), will 1.9 TD AAZ engine downpipe fit my engine? What diameter it has? Can I fit something else? Do you have any photos?
#1
by
Maarten
on 29 Dec, 2005 02:27
The downpipe will fit... but you'll have to adapt your exhaust to the different pipe. I suggest you stick with the 1.6GTD pipe (or go to a larger diameter if you need one)
#2
by
zaprzal
on 29 Dec, 2005 03:10
What diameter is 1.9 TD AAZ downpipe? Will 1.9 TDI 1Z (90hp) also fit me?
#3
by
Maarten
on 29 Dec, 2005 03:57
Ik don't know the diameter of the original 1.9 DP, I know the 1.6TD pipes are VERY restrictive (45mm internal diameter) so I swapped mine for a custom freeflow 70mm.
The turbo on a TDI is positioned different than a 1.6/1.9TD so that won't fit.
#4
by
Maarten
on 29 Dec, 2005 05:06
this is a 1.9 downpipe...
#5
by
zaprzal
on 29 Dec, 2005 05:53
Ok, thanks.
Is 1.9 td dp less restrictive than 1.6 dp? Is it worth to swap 1.6 dp for 1.9? Will it fit without any modyfications as I marked on picture? Only cut somewhere where I marked on picture and stick with rest of exhaust? Thanks for help
#6
by
Maarten
on 29 Dec, 2005 06:07
it looks less restrictive but I don't know the diameter of the pipe.. could be somewhere between 45 and 55 I think... If you cut it before the flex it could fit with some ghetto-welding
so I suggest a real upgrade
This is my pipe:
on a K24 turbo (behind the pipe on the 2nd photo is the original dp)
#7
by
zaprzal
on 29 Dec, 2005 07:30
Last question: flange which I marked on picture is this same in 1.9 and 1.6 dp?
#8
by
Maarten
on 29 Dec, 2005 07:34
Yes it will fit.. on all IDI (1.6/1.9TD) turbos the outlets are the same...
#9
by
andy2
on 29 Dec, 2005 07:39
Ok, thanks.
That downpipe pictured has a different flange used for the k03 turbo used on 1.9's from 95-97 I think.I have modified that pipe to fit on my 1.6td,the only thing you need to do is relocate the 2 bottom holes and cut the flange a little on the bottom.
If you can get a downpipe from a 93 and I think some 94's it will be a direct bolt on as those years used a k14 turbo which has the same bolt pattern as our 1.6 flange.
Other than that you'll have cut that flange off the exiting end and weld a peice of pipe onto it inorder to get the angle right underneath the car.
#10
by
zaprzal
on 29 Dec, 2005 08:21
I've got garrett T2
#11
by
andy2
on 29 Dec, 2005 10:02
I believe that the T2 has the same outlet flange as the K14,K24 and T3.Mabye someone else could confirm this?
#12
by
935racer
on 29 Dec, 2005 11:34
I've got a t2 on a 1.9 in the shop right now, just checked, flange is the same as k14, k24, t3 etc
#13
by
Maarten
on 29 Dec, 2005 14:49
:wink:
