Do these pumps interchange with any other vw Thanks
If it's from a 4cyl... it's quite possible yes... even tho it might be a newer style pump, you might have to change over the fittings from the old pump...
that is still a 4cyl... so again... I would say yes.. but you'll have to check... some of the fittings might be different, and would have to be swapped to the newer pump from the old one on u'r car at this time.
Pump off older golf was used ,return line slightly different ,pulley depth was problem. 2 pulleys bolted together solved that, all is well. Thanks
