Author Topic: pics of fmic install on mk1 rabbit? anyone?  (Read 16107 times)
August 21, 2010, 10:49:50 pm
erice1984
  • 263
« on: August 21, 2010, 10:49:50 pm »
I am looking for pictures on how people have installed front mount intercoolers.  I am considering using one when the turbo happens and was curious about how others have tackled this.
1980 Rabbit 1.9TD
Reply #1August 23, 2010, 07:05:33 am
GEE-BEE
  • 1604
Re: pics of fmic install on mk1 rabbit? anyone?
« Reply #1 on: August 23, 2010, 07:05:33 am »
Check out jack's build in the general section
Iam going to relocate my battery under the bed and use a Intercooler from cxracing.com
Size: 28 x 2.5 x 7 w, 2.5 o.d. of the tubes
I was trying to figure the mount and I will probly modify 4 of the radiator mounts that I found for my 675 mm radiator install.
I dont want all of the tubing to one side, I will have a 45 elbow coming down to the rh intercooler side
and a one 90 tube  coming from the pd150 to the lh front.
I will be using black powder coted tubing with red silicone connectors, all tubing with beaded ends
azautohaus.com
part #'
191121265C
191121265B
The 28' intercooler width is plenty, as the radiator is 26.57 wide
Stay in touch...
GB
« Last Edit: August 23, 2010, 04:29:10 pm by GEE-BEE »
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #2August 23, 2010, 08:09:34 am
VW_Commuter
  • 355
« Reply #2 on: August 23, 2010, 08:09:34 am »
Gee-Bee, did you mean CXRacing.com?  I kind of like this kit, http://www.cxracing.com/mm5/merchant.mvc?Screen=PROD&Store_Code=CXR&Product_Code=IC0049-KIT200-EB&Category_Code=ICDK200, since it looks pretty complete.
Greg
'06 Golf TDI traded in for a '12 Jeep Rubicon (the Phatbox is available)
'91 Jetta TD, a work in progress (I'll do a build thread when I start in earnest)
'65 Notchback, a project not yet started
Reply #3August 23, 2010, 08:21:07 am
erice1984
  • 263
« Reply #3 on: August 23, 2010, 08:21:07 am »
Oh that intercooler looks like a good size.
Does anyone use blow off valves on diesels? if you don't use one why not?
From my understanding the BOV is designed to extend the life of the turbo.
1980 Rabbit 1.9TD
Reply #4August 23, 2010, 09:58:59 am
truckinwagen
  • 1895
« Reply #4 on: August 23, 2010, 09:58:59 am »
a BOV is unnecessary on a diesel as there is no throttle plate closing and dead heading the turbo off throttle.
on a gasser when you lift off the throttle the throttle body closes causing a very sharp increase in pressure between the turbo and throttle body, decreasing life of the turbo(often simply snapping the shaft) and sometimes blowing the intake plumbing apart.
as a diesel has no throttle plate, there is no sharp increase in pressure off throttle, and no danger to the turbo or intake plumbing.
-Owen
83 Opel Kadett Diesel
Reply #5August 23, 2010, 10:23:39 am
erice1984
  • 263
« Reply #5 on: August 23, 2010, 10:23:39 am »
Good call!  Yeah, no throttle plate, makes more sense.  Thanks for clarifying.
1980 Rabbit 1.9TD
Reply #6August 23, 2010, 10:40:18 am
Thezorn
  • 381
« Reply #6 on: August 23, 2010, 10:40:18 am »
I actually just ordered one of those CXracing intercoolers. Im probabley going to use exhasut tubing and bend it myself for the tubes. They are cheap and from what ive read seem to work pretty good.
Compounded 93 AAZ
Reply #7August 23, 2010, 11:06:39 am
erice1984
  • 263
« Reply #7 on: August 23, 2010, 11:06:39 am »
Yeah I have seen that done before.  Steel, Aluminum, whichever is easier for you to work with.
1980 Rabbit 1.9TD
Reply #8August 23, 2010, 11:54:42 am
GEE-BEE
  • 1604
« Reply #8 on: August 23, 2010, 11:54:42 am »
Correct, CXracing
RH side:1.50 to 2.50 reducer at the turbo, than a 45 bend to the rh front to 90 degree pipe to st straight coupler to intercooler
LH Side :PD150 to straight to 90 bend to straight to 90 bend into lh intercooler
My core support is from South Africa, so there is room for this after the battery is relocated
GB
« Last Edit: August 23, 2010, 04:29:44 pm by GEE-BEE »
Giles Pump OHC
MK1 JETTA DASH
Reply #9August 23, 2010, 12:18:03 pm
bugnut
  • 89
« Reply #9 on: August 23, 2010, 12:18:03 pm »
Here are some pictures of my fmic.
1980 Rabbit  1.9/1.6 franko engine.  compound built in the works
Reply #10August 23, 2010, 01:10:54 pm
GEE-BEE
  • 1604
« Reply #10 on: August 23, 2010, 01:10:54 pm »
hey Bugnut !
Your missing your upper radiator clip
Ebay item :
270571359731
Dont worry , My wife says I cant find it either..... :o
GB
Giles Pump OHC
MK1 JETTA DASH
Reply #11August 23, 2010, 01:41:32 pm
erice1984
  • 263
« Reply #11 on: August 23, 2010, 01:41:32 pm »
thanks Bugnut
1980 Rabbit 1.9TD
Reply #12August 23, 2010, 02:34:55 pm
jack's lack
  • 275
« Reply #12 on: August 23, 2010, 02:34:55 pm »
I'll save you the trouble. It looks a lot like bug nut's though
I have seen guys on the vortex run the ones with one inlet on each side. however it would probably require moving the battery to the trunk or moving the radiator starboard a bit if possible. Mine won't move any further because the alternator is right there by the lower radiator hose. If you have A/C or an air/oil cooler it is going to be even more of a challenge.
I hope this is helpful, and good luck.
Cheers
1982 Rabbit diesel L 4 door
AAZ, K14, Giles pump, PD150 intake, P&P'd head, ceramic coated pistons, 2.5" stainless down pipe & exhaust. FK coils
My Build Thread
Reply #13August 23, 2010, 02:44:46 pm
erice1984
  • 263
« Reply #13 on: August 23, 2010, 02:44:46 pm »
PO had already relocated battery to trunk.
No A/C
No Oil Cooler
Standard V-Belt Alt. (65amp or 55.. whatever it is)
1980 Rabbit 1.9TD
Reply #14August 23, 2010, 04:30:41 pm
GEE-BEE
  • 1604
« Reply #14 on: August 23, 2010, 04:30:41 pm »
With all that moved Erice, it will be easy
PD150 ?
GB
Giles Pump OHC
MK1 JETTA DASH
