#15
by
Smokey Eddy
on 18 Jul, 2010 00:29
I'm temped to try and modify it with my dremel to make it clear... it just barely hits the pick up tube... clears the windage tray entirely. It's such a weird coincidence that it would just BARELY hit the pick up tube. its not even the tube its self it's hitting but the very edge of the flange (i think?) its hard to tell under the car in the dark with my flashlight.
#16
by
truckinwagen
on 18 Jul, 2010 00:47
bust out the dremel and go to town!
#17
by
on 18 Jul, 2010 01:34
Check that rod cap isn't on backward, then clearance the flange.
#18
by
Smokey Eddy
on 18 Jul, 2010 01:35
how do i make sure which way they go???!
#19
by
on 18 Jul, 2010 07:49
I think if you got the cap to fully seat on the rod then it is on the proper way
#20
by
on 18 Jul, 2010 08:47
on a 1.6 the side with the "bumps" goes toward the timing belt
#21
by
on 18 Jul, 2010 10:13
how is a rod cap hitting the pickup flange? its like 2 inches below the crank? least they are on my engines.
#22
by
Smokey Eddy
on 18 Jul, 2010 13:07
kevin is yours the AAZ?
the rod cap (the counter weight ON the rod cap) hits the flange part of the tube (where the tube flange joins the pump)
#23
by
on 18 Jul, 2010 14:09
AAZ must be WAY DIFFERENT from the earlier engines then. and way different than gasser engines. because my rod caps dont come that close to the oil pump. did you bolt a 1.6 or a 1.9 pump on it? did you loosen the pump to see if you could move it out of the way a little? they do have some wiggle room...
i was just assuming that an AAZ was just like a 1.6 bottom end, just with a tad longer stroke, and bigger bore size, taller block.
#24
by
OM617
on 18 Jul, 2010 14:38
Yes, more than bore and stroke alone.
#25
by
Smokey Eddy
on 18 Jul, 2010 22:19
yeah apparently. I can see where it was hitting the feed pipe. i HOPE if i grind it down it will clear. No progress today. went to the beach mostly because i really mashed my fingers last night...
#26
by
Smokey Eddy
on 22 Jul, 2010 10:20
If you found this thread from a search and are wondering what happened, this thread continues on page SIX, reply #81, of
this thread.
