Author Topic: intercooler question  (Read 2815 times)
April 24, 2010, 09:53:07 pm
TDsamurai
  • 130
« on: April 24, 2010, 09:53:07 pm »
So heres my intercooler from a early 90's diesel mitsubishi pajero.
I would like to know if anyone knows what the bottom tube on it is for? it doesn't go anywhere, its kinda in the way for what i am doing with it think i can take it off or does it do something important?
Reply #1April 24, 2010, 10:20:16 pm
mystery3
  • 774
Re: intercooler question
« Reply #1 on: April 24, 2010, 10:20:16 pm »
Was it connected to a bypass valve? I have an IC from an s13? nissan I think, right where the stock mounting location there is basically a tee, one 2" side to or from the motor and 1" side I presume for the stock bypass valve.
Reply #2April 24, 2010, 10:46:52 pm
TDsamurai
  • 130
« Reply #2 on: April 24, 2010, 10:46:52 pm »
I dont think so, it looks like just a T that splits to a dead end. I never took it off the vehicle but i dont think there is anything like that.
Reply #3April 25, 2010, 02:10:28 am
tomnik
  • 10
« Reply #3 on: April 25, 2010, 02:10:28 am »
oil drain?
Tom
Reply #4April 25, 2010, 02:15:05 am
Syncroincity
  • 727
« Reply #4 on: April 25, 2010, 02:15:05 am »
oil drain?
Tom
 ;D ;D ;D Careful, that's a sore subject...
That is an air/air intercooler, right, not an air/water?
JC McCavitt
'86 Syncro GL Camper AAZ
'98 Jetta Wolfie
'04 Passat Variant GLS 4Mo 5MT
Reply #5April 25, 2010, 12:53:12 pm
TDsamurai
  • 130
« Reply #5 on: April 25, 2010, 12:53:12 pm »
yea its just air to air, theres no fittings or valves connected to it so it cant be a drain.
Reply #6April 25, 2010, 03:01:49 pm
mystery3
  • 774
« Reply #6 on: April 25, 2010, 03:01:49 pm »
If it's just a capped off tube it could be to reduce surge in a similar manner to a water hammer reducer thing used in residential plumbing? Giving a little room for air to compress without straining components. Is the mitsubishi pajero a gasser?
Reply #7April 25, 2010, 03:05:32 pm
TDsamurai
  • 130
« Reply #7 on: April 25, 2010, 03:05:32 pm »
its a diesel intercooler, yea my guess was something to do with pressure surges or something. It hits my radiator overflow bottle when i put it where i want, so i would like to know if i can get rid of it.
Reply #8April 25, 2010, 04:33:21 pm
mystery3
  • 774
« Reply #8 on: April 25, 2010, 04:33:21 pm »
I'm not sure why there would be a "surge protector" on a diesel, I thought the main concern was about the throttle body slamming shut and having nowhere for the pressure aside from a bov/bpv but this would provide some extra space for compressed air.
Considering I/we have never seen one like this I think you'd be safe to remove it. It looks like the IC is all alloy with no plastic end caps to blow apart?
Reply #9April 25, 2010, 04:47:54 pm
TDsamurai
  • 130
« Reply #9 on: April 25, 2010, 04:47:54 pm »
yup all metal, and theres even i nice little fan built into the backside. got that unit for $75
Reply #10April 26, 2010, 06:43:37 pm
4wheeler
« Reply #10 on: April 26, 2010, 06:43:37 pm »
Nice little cooler.
looks like you can get rid of anything but the in and out ..
Put it over the engine and use a subaru scoop .. works great...easy to plumb
Reply #11April 26, 2010, 07:23:35 pm
TDsamurai
  • 130
« Reply #11 on: April 26, 2010, 07:23:35 pm »
not quite enough hood clearance in the samurai to go centered, gonna be offset to driver side not sure what type of scoop to use yet might make a custom one, i also found a 2000cfm 10" fan from perma-cool that will be a good upgrade in the near future.
