Well, as many of you know, I had a bearing spin out on my newly acquired Caddy.
I thought I could simply sawp out the old bearings with new ones but it seems the previous owner let it run with no #2 bearing for a little while. No remnants were found when I pulled the pan...well, other than the ones in the bottom of the oil pan and in the screen of the oil pickup.
I checked the rod journals....they were all fine and ordered the replacement bearings accordingly, but as I found out, I forgot to measure the crank journal....long story short, see below:
That's 47.45mm....almost 0.5mm below spec...talk about being ground down a little...
So now, I have the TD crank out, and I am looking to replace it with an extra NA crank I had laying around. That crank is fine. I have checked and rechecked it's measurements.
Time to order my parts and get cranking (no pun intended) on putting this thing back together. I really am chomping at the bit to get it back on the road and enjoying the TD Caddy lifestyle.
But in the mean time this is what my garage looks like:
and here's the current state of my engine:
