#195
by
vwzzuk
on 07 Dec, 2014 14:32
Question: Has anyone documented the fuel mileage loss/gain after the governor mod?
#196
by
on 07 Dec, 2014 18:18
Like with most diesel performance mods, you will see a mileage whack if you use your newfound abilities, but there shouldn't be any difference under general driving. If you start spinning your engine up to 4500 RPM regularly with the pedal to the floor then yep, you're going to use more fuel. But if you just drive around exactly the same as you did before you'll get about the same mileage.
#197
by
94bruce
on 11 Mar, 2015 14:05
Hi i am new to diesel tuning.
Have 1.6td (JX) in my 1989 vw transporter.
Was looking into this gov mod but is it worth shimming the main spring, if i don't want it to rev more than 4500rpm.
and read you don't shim the intermediate spring. So will shimming the main spring stop it reducing fuel before it cuts off at 4500rpm.
thanks
#198
by
on 11 Mar, 2015 15:42
Correct, leave the intermediate spring alone. It doesn't cut off fuel, just improves the behavior of the vehicle at normal driving RPMs.
There isn't any way to leave the 4500 RPM limit in place while reducing the cutoff as it approaches 4500. You can only have one or the other - shimming the main spring will move the fuel cutoff to higher RPMs.
#199
by
vwzzuk
on 14 Mar, 2015 20:58
Thanks.
I'm going to have to do this mod on my pickup. Just seems like a valuable performance modification...especially for climbing hills.
#200
by
vwzzuk
on 23 May, 2015 20:55
OK, I did the governor mod last night when I had the engine out for another transmission.
I have the fast idle pump version. I shimmed the main spring a total of 3.48mm using 3 washers. I notice also that the main spring seat near the middle of the unit has a tapered collar in the middle. So, I used a washer that was large enough to fit around the taper to sit all the way down on the spring seat and shimmed from there.
Problem: When I started up the pickup, it idles at around 3000 rpms or so. Way to high of course. Could I have misplaced my throttle shaft position, that is, have it out 180 degrees? I understand that there are no major idle adjustments when you put it all back together to get rpms down or up as it remains close to the same and you are ready to drive like normal.
Any suggestions?
#201
by
on 24 May, 2015 11:17
180 degrees out is a big difference. One or two splines though can easily bump it up to 3k.
#202
by
vwzzuk
on 24 May, 2015 14:05
I don't know if it can be out 180 degrees. That's the only thing I can think of that may be different from before I messed with it.
I made a mark on the plate so that I could get the throttle shaft back in the same position. It is in the same location because the top of the accelerator shaft has a slot on top and its aligned with my marks. Can they be out 180? I would think the bottom of the shaft with the riveted arm would only go so far one way or the other inside the pump. Maybe I have something hanging-up inside?
I guess I will have to take it apart again and look. Dang!
#203
by
vwzzuk
on 24 May, 2015 17:02
So, I've established that the shaft can only go in one way so the 180 degree out idea is not valid.
I altered the fuel screw position to get it down to a reasonable (but higher than stock) idle. When you started it, it would have difficulty evening out to the idle.
This is weird. Seems like everyone has a strait forward governor mod. I believe I did everything right but this pump doesn't seem to respond well.
So, I'm going to take the shims out and see if the pump goes back to normal. Hummmmm.
-dave
#204
by
vwzzuk
on 24 May, 2015 20:30
Update: I took apart an identical fast idle pump to see what the stock spring assembly looked like in case my existing pump was different. They were both the same.
I took out the shims to see if it would return to stock performance and run without the shims properly. Answer is yes.
So, whats the deal? One can do the governor mod successfully on some 1.6NA pumps but not all of them?
Do I have to get a specific pump like a 107A?
Do you have to alter the fuel screw, idle screw or anything else after the governor mod is performed?
#205
by
on 25 May, 2015 06:39
The fuel screw definitely needs to be adjusted any time you take the lid off of the pump. Idle speed too.
Can you post a picture of your shim job?
#206
by
vwzzuk
on 25 May, 2015 10:13
Looks like the attachment link doesn't work for posting pics in Safari or Firefox on a Mac.
#207
by
on 25 May, 2015 12:45
most of us use photobucket or some other image hosting service.
If you try to use the lid and arm from an opposite rotation pump, it will be 180 out, and won't work.
It's pretty easy to get one spline off, just saying...
#208
by
vwzzuk
on 03 Jun, 2015 07:43
#209
by
on 03 Jun, 2015 19:23
Shim looks correct... Probably a bit more aggressive than mine but looks fine.
You absolutely do have to adjust the various pump settings after having it apart. I don't think your issues are caused by your changes unless something is binding. Can you still pull on the end of the governor capsule and have it move freely, in particular the intermediate spring?
