TDI and IDI cam question?
by
on 19 Jan, 2010 10:59
is there any gains from the TDI cam? will it even work? just a thought i had...
#1
by
blackdogvan
on 19 Jan, 2010 14:18
Nawww, AAZ cam is a upgrade for a 1Z/AHU.
#2
by
on 19 Jan, 2010 18:01
yeah i was thinking an older cam is probably better because of the later emissions
#3
by
smutts
on 20 Jan, 2010 13:17
Well, no AAZ's at our local friendly breaker, so an early TDi cam out of a Mk3 passat it is. Unknown miles, which is a nuisance as the mileometers in these things are electronic, so who knows? Undecided. Just for the interested the lobe measurements were, Base circle 37.98mm, Best Tip to Base 46.28mm, Worst 46.12mm.
So lift would be assumed as 8.3mm. But looks as though some wear is on its way. 0.16mm, but hopefully it will make less racket than the present occupant. Wish me luck. Grin
Hmm....... Deep thought. Just measured the cam as is in the engine. This is a SB engined GTD, so should be the real deal, Base Circle same or similar to above 37.98mm No.1 cam peak I measure 46.82mm, No.2 is 45.80mm, No.3 is 46.81mm, Oh joy, clapped cam, I have found it! No.4 45.82mm WTF says I, No.5 45.82mm, depression setting in, No.6 46.80mm, No.7 45.82mm, No.8 46.82mm. So the good news is I have a fine camshaft, If I have it right, the valves go EIEIIEIE, if so then Exhaust lift is 8.84mm ish, Intake lift is 7.84mm ish. Weird, go figure. Huh
Here was the full monty.
http://www.vwdiesel.net/forum/index.php?topic=21328.msg164903#msg164903Should give you an idea of what you are up against.
#4
by
blackdogvan
on 20 Jan, 2010 14:22
Just missing one tiny important bit...
#5
by
ryanp
on 20 Jan, 2010 15:41
Does it seem an AEY is an upgrade for IDI and TDI??
#6
by
blackdogvan
on 20 Jan, 2010 16:31
Anyone remember the lift numbers for the AAZ cam?
#7
by
NintendoKD
on 20 Jan, 2010 19:22
Since we are on the cam subject, my aaz cam needs a cam gear, didn't come with one. Is there a substitute, or do I have to use the aaz cam?
#8
by
on 21 Jan, 2010 07:58
put a 1.6 cam sprocket on it
#9
by
on 21 Jan, 2010 14:44
can we dig up the numbers of 1.5, n/a cams, eco cams, and 1.6td cams? perhaps different years were different as well. also the aey and 1y are very similar and may have the same cam
#10
by
NintendoKD
on 21 Jan, 2010 21:11
Wait! don't tell me that the turbo cam and the N/A cam sprocket are different, I just got one from another member.
#11
by
on 22 Jan, 2010 06:35
the lift atleast, is the same on all diesel cams ive played with. my 1.5, 1.6, and 1.6td all have roughly the same lift.
#12
by
foxracer1
on 22 Jan, 2010 09:52
The cam sproket isn't but the cam specs may be slightly. Nothing major. Physically All IDI cam interchange and i believ so do TDI cams.
