WTB - brackets and pulleys for Alt w/o A/C
by
red64chevelle
on 02 Jan, 2010 18:10
Hello all,
As part of my cleaning up of the engine bay, I would like to get rid of my non-working A/C. So, I need the brackets and pulleys to convert over. Its a 1.6TD, no P/S.
Thanks in advance.
-Dan
#1
by
ilikevwdiesel
on 02 Jan, 2010 19:11
do you have the non AC alternator? I have a mk2 set for 30 bucks.
#2
by
red64chevelle
on 03 Jan, 2010 06:48
I have a mk1 w/ AC Alt. I don't mind having to get a new one (w/o AC) though.
#3
by
on 03 Jan, 2010 21:45
Search my name "fatmobile" over on the vortex.
Check my watched topics, there is a recent link to just what you are asking for.
#4
by
red64chevelle
on 04 Jan, 2010 09:16
I am not seeing it. Only the thread with someone looking for it, not for sale.
#5
by
on 04 Jan, 2010 09:26
It's there,.. but looks like it got black holed.
I figure it was black holed because the poster sells too many things without paying vortex.
They shut down vwpieces because of that.
Check his other posts.
See if he reposted it,
or send him an IM/email
#6
by
red64chevelle
on 04 Jan, 2010 09:41
If your talking about "tifatchance", I just sent him an e-mail.
#7
by
red64chevelle
on 04 Jan, 2010 10:56
Just got the reply, and he sold them last week, so still on the hunt.
Whats the difference between mk1 and mk2 brackets?
#8
by
ilikevwdiesel
on 04 Jan, 2010 14:51
The Mk2 bracket uses a 10mm pivot bolt so the alternator doesn't suffer from "egged pivot bolt hole" syndrome like most of the mk1 cars end up doing. If you're getting rid of your AC I would recommend using a Mk2 bracket and alternator as they are much more rugged.
#9
by
red64chevelle
on 04 Jan, 2010 18:09
If your setup has the pulley's and such, I'll take it. Just PM me the paypal info.
#10
by
ilikevwdiesel
on 04 Jan, 2010 18:14
I don't think I have any pulleys but aren't the crank and waterpump pulleys the same? The only diff is the offset on the alt. anyone want to chime in on this?
#11
by
maxfax
on 04 Jan, 2010 19:41
Crank and water pump pulley should be the same.. The only difference I've noticed is that some MK2's have a cast crank pulley instead of the stamped steel..
#12
by
on 04 Jan, 2010 21:35
I think the A2 alternator bracket puts the alternator closer to the belt,...
but I'm not sure
so a shorter neck will work.
That should be easy to find.
The hard thing to find is a neck as long as the non-AC A1 bracket requires.
#13
by
ilikevwdiesel
on 05 Jan, 2010 03:03
but I'm not sure
uhhhh...ok.
anyways what I have are the cast iron bracket that mounts on the block and the steel bracket for the slide bolt, all you need to find is the correct alternator with the appropriate pulley on it, that is one from a mk2 without AC. Go to vagcat.com and play with the part numbers. I bet Mk2 gassers use the same alternator pulley.
#14
by
red64chevelle
on 05 Jan, 2010 05:33
Well, I think the GAP and Advance alternators come with pulleys. I am going to swing by a buddy of mines house and check out what the difference is between AC and W/o AC. I would like to get the W/o AC pulley and the W/ AC alternator so I can have 90 Amps vice 65 Amps.
