Author Topic: WTB - brackets and pulleys for Alt w/o A/C  (Read 7494 times)
January 02, 2010, 06:10:26 pm
red64chevelle
  • 67
« on: January 02, 2010, 06:10:26 pm »
Hello all,
As part of my cleaning up of the engine bay, I would like to get rid of my non-working A/C.  So, I need the brackets and pulleys to convert over.  Its a 1.6TD, no P/S.
Thanks in advance.
-Dan
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
1964 Malibu Convertible
Reply #1January 02, 2010, 07:11:58 pm
ilikevwdiesel
  • 1202
    • Erupt into a BEVRAGE this summer with Glug!
Re: WTB - brackets and pulleys for Alt w/o A/C
« Reply #1 on: January 02, 2010, 07:11:58 pm »
do you have the non AC alternator? I have a mk2 set for 30 bucks.
Look, if corn and kudzu fall in love and have a baby in a lab under the supervision of scientists working in my employ, WHO AM I TO STOP THAT other than the CEO responsible for stopping it???
My Bio
Reply #2January 03, 2010, 06:48:22 am
red64chevelle
  • 67
« Reply #2 on: January 03, 2010, 06:48:22 am »
I have a mk1 w/ AC Alt.  I don't mind having to get a new one (w/o AC) though.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
Reply #3January 03, 2010, 09:45:12 pm
  • 2920
« Reply #3 on: January 03, 2010, 09:45:12 pm »
Search my name "fatmobile" over on the vortex.
 Check my watched topics, there is a recent link to just what you are asking for.
Tornado red, '91 Golf 4 door,
Reply #4January 04, 2010, 09:16:02 am
red64chevelle
  • 67
« Reply #4 on: January 04, 2010, 09:16:02 am »
I am not seeing it.  Only the thread with someone looking for it, not for sale. ???
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
Reply #5January 04, 2010, 09:26:49 am
  • 2920
« Reply #5 on: January 04, 2010, 09:26:49 am »
It's there,.. but looks like it got black holed.
 I figure it was black holed because the poster sells too many things without paying vortex.
 They shut down vwpieces because of that.
 Check his other posts.
 See if he reposted it,
 or send him an IM/email
Reply #6January 04, 2010, 09:41:10 am
red64chevelle
  • 67
« Reply #6 on: January 04, 2010, 09:41:10 am »
If your talking about "tifatchance", I just sent him an e-mail.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
Reply #7January 04, 2010, 10:56:29 am
red64chevelle
  • 67
« Reply #7 on: January 04, 2010, 10:56:29 am »
Just got the reply, and he sold them last week, so still on the hunt.
Whats the difference between mk1 and mk2 brackets?
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
Reply #8January 04, 2010, 02:51:22 pm
ilikevwdiesel
  • 1202
« Reply #8 on: January 04, 2010, 02:51:22 pm »
The Mk2 bracket uses a 10mm pivot bolt so the alternator doesn't suffer from "egged pivot bolt hole" syndrome like most of the mk1 cars end up doing. If you're getting rid of your AC I would recommend using a Mk2 bracket and alternator as they are much more rugged.
My Bio
Reply #9January 04, 2010, 06:09:29 pm
red64chevelle
  • 67
« Reply #9 on: January 04, 2010, 06:09:29 pm »
If your setup has the pulley's and such, I'll take it.  Just PM me the paypal info.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
Reply #10January 04, 2010, 06:14:38 pm
ilikevwdiesel
  • 1202
« Reply #10 on: January 04, 2010, 06:14:38 pm »
I don't think I have any pulleys but aren't the crank and waterpump pulleys the same? The only diff is the offset on the alt. anyone want to chime in on this?
My Bio
Reply #11January 04, 2010, 07:41:28 pm
maxfax
  • 2126
« Reply #11 on: January 04, 2010, 07:41:28 pm »
Crank and water pump pulley should be the same..  The only difference I've noticed is that some MK2's have a cast crank pulley instead of the stamped steel..
Reply #12January 04, 2010, 09:35:53 pm
  • 2920
« Reply #12 on: January 04, 2010, 09:35:53 pm »
I think the A2 alternator bracket puts the alternator closer to the belt,...
 but I'm not sure
 so a shorter neck will work.
 That should be easy to find.
 The hard thing to find is a neck as long as the non-AC A1 bracket requires.
Reply #13January 05, 2010, 03:03:07 am
ilikevwdiesel
  • 1202
« Reply #13 on: January 05, 2010, 03:03:07 am »
 but I'm not sure
uhhhh...ok. ??? anyways what I have are the cast iron bracket that mounts on the block and the steel bracket for the slide bolt, all you need to find is the correct alternator with the appropriate pulley on it, that is one from a mk2 without AC. Go to vagcat.com and play with the part numbers. I bet Mk2 gassers use the same alternator pulley.
« Last Edit: January 05, 2010, 03:18:02 am by ilikevwdiesel »
My Bio
Reply #14January 05, 2010, 05:33:04 am
red64chevelle
  • 67
« Reply #14 on: January 05, 2010, 05:33:04 am »
Well, I think the GAP and Advance alternators come with pulleys.  I am going to swing by a buddy of mines house and check out what the difference is between AC and W/o AC.  I would like to get the W/o AC pulley and the W/ AC alternator so I can have 90 Amps vice 65 Amps.
2003 Jetta GL TDI
1999 Beetle GLS TDI
1987 Cabby
1984 Jetta TD
1984 Rabbit GTI
