Author Topic: What to do about the snorkel?  (Read 5560 times)
December 22, 2009, 05:11:48 am
rs899
  • 647
« on: December 22, 2009, 05:11:48 am »
I have a  '91 MKII Jetta NA and it has this odd dryer vent  ...er snorkel arrangement that I need to deal with.  The PO ripped it out of its anchor in the passenger side fender, and I see that it is a (very dirty) foam over wire cage thingus.  The glue on the seam that holds the foam together is coming apart.  At a minimum I should think I ought to clean the thing and glue it all back together (and add some cable ties to keep it out of the belts), but is it really effective anyway?  What do you guys use for breathing on one of these?
Rick
Reply #1December 22, 2009, 08:17:04 am
Re: What to do about the snorkel?
« Reply #1 on: December 22, 2009, 08:17:04 am »
you could always fab up your own intake hose.
Reply #2December 22, 2009, 09:16:58 am
GEE-BEE
  • 1604
« Reply #2 on: December 22, 2009, 09:16:58 am »
You could install a 1Y intake and inlet pipe and run a 2.25 I.D. air filter assy.
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
Reply #3December 22, 2009, 02:08:16 pm
blackdogvan
  • 574
« Reply #3 on: December 22, 2009, 02:08:16 pm »
PVC pipe & glue does count as fabrication... ;)
1991 Vanagon 1.9 mTDI
Reply #4December 22, 2009, 05:39:27 pm
« Reply #4 on: December 22, 2009, 05:39:27 pm »
The upper rad hose off of a 90 F250 7.3 IDI is just about long enough. If you add in a flex section I'm sure it would work well. You do have to do some trimming to make it fit onto the elbow off the airbox though
You can kind of see what is going on here
http://img.photobucket.com/albums/v603/burnyourmoney/DSC08119.jpg
« Last Edit: December 22, 2009, 05:41:23 pm by burn_your_money »
Reply #5December 22, 2009, 08:16:32 pm
« Reply #5 on: December 22, 2009, 08:16:32 pm »
:P well technically.. lol anything you made, you fabricated. No? oh burnnn lol I wouldn't use the PVC, but it is an option.. course you could always run nothing too lol
Reply #6December 23, 2009, 03:50:57 am
rs899
  • 647
« Reply #6 on: December 23, 2009, 03:50:57 am »
I am sure that I can come up with something equally as creative as you all, but , back to my question (restated).
Is there any advantage/reason to keep the stock setup with this looong foam contraption?  Or, why did they make it like THAT?
Rick
Reply #7December 23, 2009, 04:52:38 am
« Reply #7 on: December 23, 2009, 04:52:38 am »
I think the foam is a for sound deadening.
