General Information
General
What to do about the snorkel?
Topic: What to do about the snorkel? (Read 5652 times)
December 22, 2009, 05:11:48 am
rs899
December 22, 2009, 05:11:48 am »
I have a '91 MKII Jetta NA and it has this odd dryer vent ...er snorkel arrangement that I need to deal with. The PO ripped it out of its anchor in the passenger side fender, and I see that it is a (very dirty) foam over wire cage thingus. The glue on the seam that holds the foam together is coming apart. At a minimum I should think I ought to clean the thing and glue it all back together (and add some cable ties to keep it out of the belts), but is it really effective anyway? What do you guys use for breathing on one of these?
Rick
'91 Jetta 1.6 NA, '82 Caddy 1.6NA, '81 Cabriolet, 4 Mercedes OM616/617s , 2 Triumphs and a Citroen DS19 in a pear tree.
December 22, 2009, 08:17:04 am
Re: What to do about the snorkel?
December 22, 2009, 08:17:04 am »
you could always fab up your own intake hose.
December 22, 2009, 09:16:58 am
GEE-BEE
December 22, 2009, 09:16:58 am »
You could install a 1Y intake and inlet pipe and run a 2.25 I.D. air filter assy.
GB
KO4/KO3 Hybrid turbo
Giles Pump OHC
MK1 JETTA DASH
15x6 Le Casletts 195-45-15
December 22, 2009, 02:08:16 pm
blackdogvan
December 22, 2009, 02:08:16 pm »
PVC pipe & glue does count as fabrication...
1991 Vanagon 1.9 mTDI
December 22, 2009, 05:39:27 pm
December 22, 2009, 05:39:27 pm »
The upper rad hose off of a 90 F250 7.3 IDI is just about long enough. If you add in a flex section I'm sure it would work well. You do have to do some trimming to make it fit onto the elbow off the airbox though
You can kind of see what is going on here
http://img.photobucket.com/albums/v603/burnyourmoney/DSC08119.jpg
Last Edit: December 22, 2009, 05:41:23 pm by burn_your_money
December 22, 2009, 08:16:32 pm
December 22, 2009, 08:16:32 pm »
Quote from: blackdogvan on December 22, 2009, 02:08:16 pm
well technically.. lol anything you made, you fabricated. No? oh burnnn lol I wouldn't use the PVC, but it is an option.. course you could always run nothing too lol
December 23, 2009, 03:50:57 am
rs899
December 23, 2009, 03:50:57 am »
I am sure that I can come up with something equally as creative as you all, but , back to my question (restated).
Is there any advantage/reason to keep the stock setup with this looong foam contraption? Or, why did they make it like THAT?
Rick
December 23, 2009, 04:52:38 am
December 23, 2009, 04:52:38 am »
I think the foam is a for sound deadening.
General Information
General
