AAZtd into 1985 MK2 gasser,ACN trans what clutch/flywheel
by
scraperhand
on 06 Dec, 2009 06:25
Hi All,
first post,putting a aaz td into my old golf mk2,i want to use the acn code trans as i like the ratios,do i need to use the gasser clutch flywheel or just change the clutch disc to match splines,thanks for any help
#1
by
on 06 Dec, 2009 09:51
I think the splines are the same. I'm pretty sure that is exactly what I have in my car. I keep forgetting my tranny code for some reason though.
Keep the diesel flywheel. TDC isn't marked on the gasser one. It's 8 degrees off or something to that effect.
You'll probably hate the ratios with the AAZ though. Mine is NA and I find them too short.
#2
by
on 06 Dec, 2009 10:34
99% sure you will want to take everything from the aaz and put it on the acn. I bought a 1.9 flywheel to put on my 1.6TD as it has a larger diameter and should have more holding power. I believe you want a 210mm clutch setup with the small 24 spline hub
#3
by
rallydiesel
on 06 Dec, 2009 11:03
ACN is about as good as you'll get for an 020. I've got a 4S 020 and it sucks above 80 km/h because it's geared too short and the 4S is an oem diesel trans. If you popped a .71 fifth in the ACN you'd have probably the best 020 diesel ratios.
#4
by
scraperhand
on 06 Dec, 2009 16:18
Thanks for the replies,ive got a ff with the .71,might just raid it for fifth gear,looking forward to getting the beast on the road.
#5
by
scraperhand
on 11 Jan, 2010 16:38
Finally enough time to work on my car,the thing is on the azz the flywheel bolts to the crank instead of the other way round like the 8 valve tha was in it,any suggestions,plz
#6
by
rabbitman
on 11 Jan, 2010 19:51
This,
http://www.scirocco.org/gears/ says the stock FF and ACN are the aaalmooost the same in fifth gear, at 5000rpm the FF will go 125mph and the ACN will go 126mph, the ACN with a .71 fifth will go 133mph.
Almost not worth the effort of swapping fifth gear.
#7
by
on 11 Jan, 2010 20:35
Your AAZ came from a Passat then with a 02A tranny. You can get the AAZ clutch setup that is the same as the 020
#8
by
Patrick
on 12 Jan, 2010 03:16
Tyler is right. I'm running a stock diesel 210 mm clutch ('93-'93 mk3 golf/jetta) on an AAZ in my 92 jetta with an 020 trans. Other option (using in the one I'm building) is a 16V pressure plate with the 8V gasser disc with the diesel flywheel. Supposed to be good for more torque.
#9
by
scraperhand
on 12 Jan, 2010 04:58
Ok got it,can i use any diesel flywheel or does it have to be aaz 020 specific,thanks again
#10
by
on 12 Jan, 2010 10:09
well, if the flywheel mounts to the crank, you cant use it.
if the flywheel bolts to the pressure plate then the crank, you can use it.
#11
by
on 12 Jan, 2010 19:09
Just make sure that whatever flywheel you use has the proper TDC mark on it. Gas ones don't always
#12
by
on 14 Jan, 2010 10:22
if you are good enough, you can scribe a proper mark on a gasser wheel tho. and they are MUCH lighter.
