#45
by
aidan
on 23 Dec, 2009 12:32
#46
by
oldskool rich
on 24 Dec, 2009 04:59
ye i think i will go for a HE221W if thats been tried and tested, dont suppose you know what cam hes got?
im lookin for a good sports clutch but cant find anything, a few years back sumone on here showed me a website in the states that sold every clutch you can think of, and colour coded them for differnt uses, think it was green yellow and red from stock to race use, does anyone know about this? i realy need to find it again if anyone knows?
#47
by
on 24 Dec, 2009 05:47
#48
by
oldskool rich
on 24 Dec, 2009 11:42
thanx very much thats exactly what i wanted
#49
by
svenakela
on 24 Dec, 2009 14:18
I have Clutchnet clutches, very nice parts.
#50
by
oldskool rich
on 24 Dec, 2009 17:43
will i be ok to use red clutches for daily use or will they run out quickly?
i was gona use a x2 preasure plate and 6 Button Quick Lock (solid hub) clutch
will that be ok, im guessing will be quite jerky to drive, clutch will be either on or off, but 5 pot has so much torque at idle that you cant stall it so i cant see this being a problem, just wana know if it will last, dont wana be changing it every 6 months, or should i go with a yellow clutch but keep with the red x2 preasure plate?
#51
by
on 24 Dec, 2009 19:41
George told me they don't mix the colors of the parts. I am sure they do. I went with the 6 puck sprung hub in RED with the RED pressure plate... I don't have it on the car yet. 53 Willys and zukgod both have clutchnet RED sprung setups and said they worked fine for them.
#52
by
oldskool rich
on 25 Dec, 2009 03:29
will there be a big difference between sprung and solid?
#53
by
svenakela
on 25 Dec, 2009 06:00
I have a solid, the reseller here said I'll be ok with a solid and I think that too. They have both standard clutches without the dampeners and racing discs with them, and vice verse. But if you're going high performance it might be too aggressive (specially with the spring plate) without the low bottom torque.
Give them a call and ask. I think they will guide you.
#54
by
MJF
on 25 Dec, 2009 07:14
Dunno exact specs, ~260 degrees. Custom grinded at R-Koneistus. GT32 would be other nice turbo. Spools pretty nice even with 1,9.
#55
by
on 25 Dec, 2009 11:01
Basically George said that the sprung hub would absorb a little more drivetrain shock for daily driving and make it all last longer. The solid hub he said was more for racing and is a complete on off switch, which he said was best for drag racing lauches. I plan on using mine daily so I went with the sprung hub.
#56
by
svenakela
on 25 Dec, 2009 14:35
Interesting. On their web site they actually have discs without springs rated as green ("street upgrade") which is supposed to be for cars with 10-15 % increase. It's a clutch like that I have.
Anyway, the dampened clutch will for sure be smoother. Wise to choose it.
#57
by
oldskool rich
on 27 Dec, 2009 18:47
ok lets do this, i just bort the 260 nozzles and a brand spanking new HE221W coverd zero miles
now just need clutch, injection pump and was looking at getting a 5 to 1 aftermarket manifold off a 20v AAN and bodging it to fit. i think the inlet is ok, will do a bit of porting too, also need a cam, anyone know of a cheap place?
this is looking good peeps, i feel this is the start of sumthin beautifull i will post pics as soon as i have any
#58
by
MJF
on 27 Dec, 2009 22:09
Why dont you look 10 valve gasser manfold? Itīs bolt on, 20v is not even near
#59
by
oldskool rich
on 28 Dec, 2009 06:30
ye i know, but i cant find one for cheap, theres a 20v one goin for Ģ100 on ebay
had a quick look for 10v on the web and one came up for $1000
id rather make my own
