Fixmyvw.com
Author Topic: GOVERNOR MOD  (Read 28494 times)
Reply #30January 25, 2010, 12:06:01 pm
Re: GOVERNOR MOD
« Reply #30 on: January 25, 2010, 12:06:01 pm »
there are FAQ's but people just dont know what spring to shim most of the time.
but that pic you posted up this time, its perfect. thats the way to do it.
we really need to clear up the confusion about governor mods in the FAQ...
Reply #31January 25, 2010, 03:07:29 pm
dts67
  • 68
Re: GOVERNOR MOD
« Reply #31 on: January 25, 2010, 03:07:29 pm »
If you take the lever in both hands and pull it youll see how it works, at WOT the 2 smaller are fully compressed anyway, shimming them makes no gain imo, only ruins part throttle and idle control.
Reply #32January 27, 2010, 01:34:46 pm
  • Administrator
Re: GOVERNOR MOD
« Reply #32 on: January 27, 2010, 01:34:46 pm »
My bad Kevo, thanks for clearing it up  ;D
So in my pics is what NOT to do or you WILL have driveability issues with a solid shimmed INTERMEDIATE spring.
This pic (from a considerable consensus) is the proper method on how to do the "Governor Mod" correctly! Sorry for the confusion in my last post! lol This will effectively allow the pump to feel that it has a stiffer main spring and allow for more fuel at all rpm ranges under load.
p.s are there actually any definitive DIY's out there that properly outline the steps needed and the correct shims to put in the correct spots? lol
DING DING DING!  We have a winner!!
Hope you don't mind but I've copied the pic and stuck in on my own server so there's another one out there (seems people's Imageshack links always go dead by the time I want to read the articles again) - so for posterity and all you future thread searchers here's the pic again just in case:
Reply #33January 27, 2010, 09:27:47 pm
Re: GOVERNOR MOD
« Reply #33 on: January 27, 2010, 09:27:47 pm »
Np Vanbcguy. MIGHT I SUGGEST copying this entire thread I have put together to your server as well.
http://www.vwdiesel.net/forum/index.php?topic=24323.0
I took all the broken threads on here and vortex.. all the pictures describing the best method.. and information from other sources as well, and compiled them in to a nice little thread in our FAQ section :)
Reply #34January 27, 2010, 09:42:58 pm
Re: GOVERNOR MOD
« Reply #34 on: January 27, 2010, 09:42:58 pm »
Does anybody have experience with what will happen when shimming the main spring with something solid?
There was question raised.. and i wish to find an answer for it for my governor thread :)
TIA!
Reply #35January 28, 2010, 08:39:01 am
dts67
  • 68
Re: GOVERNOR MOD
« Reply #35 on: January 28, 2010, 08:39:01 am »
This pic any good? Theres loads more random pump part pics on my photobucket for anyone wanting to use them, 'del635'.
Shimming the governor solid, messes up the lda? ie no smoke control?
Reply #36January 28, 2010, 12:48:30 pm
Re: GOVERNOR MOD
« Reply #36 on: January 28, 2010, 12:48:30 pm »
How many mm's of washers would you say you added to the Main spring on the right? How is it to drive? any irregularities on acceleration, cruising, up hills? Good power through the entire RPM range? seems, you've almost got the main srping shimmed right solid..
I am very interested to hear of your experience with it this way. :)
Reply #37January 28, 2010, 02:37:40 pm
dts67
  • 68
Re: GOVERNOR MOD
« Reply #37 on: January 28, 2010, 02:37:40 pm »
No problems at all at part throttle at any load, the rpms do not hang at all either between gears. There is still travel in the main spring, cant remember exactly how much tbh maybe about a 1/4 of original and there is also much more tension, I thought this was needed for the lda otherwise there would be nothing for it to hold back on off boost. The cars pulls harder above 3k rpm at full throttle much different to the non shimmed lever where power just tailed away to nothing.
I used to have the smaller spring shimmed as well there was no noticable power difference at full throttle and at part throttle it was hard work keeping the car at a constant speed, you had to constantly adjust the pedal back forward it was only after this did I really understand just what the governor is doing at all rpms/loads its not just a rev limiter.
The one thing I dont like about the gov mod is the lack of no load speed limitation, eg I was trying to pull another car which was stuck in snow and when my wheels lost grip a quick blip of the pedal saw over 6k rpm! :o I cant let anyone drive my car either as it would take a matter of seconds to blow the engine to pieces but all in with a bit of sense it is an excellent mod for free hp.
Reply #38January 29, 2010, 03:25:49 am
gldgti
  • 488
    • http://scramjetsite.8m.com
Re: GOVERNOR MOD
« Reply #38 on: January 29, 2010, 03:25:49 am »
good point about having no rev limit at all - and others driving your car...
i guess it wouldnt be a huge job to wire a relay into the stop solenoid, trigerred by an electronic overspeed signal (either from tach or something else). cut fuel at specific rpm.....
'91 Golf Cabrio 1.9TD
Reply #39February 06, 2010, 03:03:23 pm
professor
  • 14
Re: GOVERNOR MOD
« Reply #39 on: February 06, 2010, 03:03:23 pm »
how do we do that? anyone do this? anyone have an electric scheme of that?
thks
Reply #40February 06, 2010, 03:30:13 pm
Re: GOVERNOR MOD
« Reply #40 on: February 06, 2010, 03:30:13 pm »
im about this far shimmed up too. (~3/16") i really cant tell any difference driving the car, other than it has alot more power and turns about 7000 rpms after the mod.
it blew alot more blackness after the mod.
Reply #41February 08, 2010, 03:04:54 am
gldgti
  • 488
Re: GOVERNOR MOD
« Reply #41 on: February 08, 2010, 03:04:54 am »
thks
let me think on it a while, i'll get back to you :-)
Reply #42February 20, 2010, 09:03:53 am
professor
  • 14
Re: GOVERNOR MOD
« Reply #42 on: February 20, 2010, 09:03:53 am »
thks
hi
don't forget this ;D
thanks
Reply #43February 20, 2010, 05:40:11 pm
kaneb
  • 164
    • www.dasdubbers.org
Re: GOVERNOR MOD
« Reply #43 on: February 20, 2010, 05:40:11 pm »
I just did mine today.  I'll see how it turns out once i have the engine in the car.  Except i shimmed mine at the end of the main spring.  Like in the photo above to your far right.  Hope it works out, am strongly thinking i'm going to want a tach for this thing.
Kane
2004 Tdi sport-daily
1983 Rabbit TD-go kart
www.dasdubbers.org
Reply #44February 20, 2010, 10:38:16 pm
Re: GOVERNOR MOD
« Reply #44 on: February 20, 2010, 10:38:16 pm »
to bad you didn't wait till after you had the engine in, could have saw the gains on the butt-dyno lol
How did it go? did you use a new seal for the pump top?
Fixmyvw.com
