General Information
Troubleshooting
How to remove brake proportioning valve?
Topic: How to remove brake proportioning valve? (Read 3383 times)
November 19, 2009, 07:19:24 pm
Makebeleaf
November 19, 2009, 07:19:24 pm »
96 Golf TD
I went to the wrecker and found a couple of these valves on the old cars. I need a new one for mine (Leaking fluid).
They look like they are in good shape but I can't get them off. Rusty bolts. Anyone have a way to get them off? Should I be turning the 2 Allen key bolts?
They look as though they run straight through the Aluminum body and into the bracket of the car.
I started on the allen bolts and my allen key just chewed the heads up....they weren't going to turn.
I believe there is only the 2 allens and then the bottom bolt(13mm?) to remove the valve.
Why is it so hard to remove?
November 19, 2009, 08:52:04 pm
macka
Re: How to remove brake proportioning valve?
November 19, 2009, 08:52:04 pm »
you need to soak the bolts with penetration fluid. The other option is to use a broken bolt extractor and that's hit and miss too.
Quote from: Vincent Walden
I do know that I drive torque, while listening to my friends prattle on about horsepower.
November 20, 2009, 03:16:27 am
Makebeleaf
November 20, 2009, 03:16:27 am »
So I do need to remove the 2 allen head bolts to get it off?
November 20, 2009, 05:45:51 am
macka
November 20, 2009, 05:45:51 am »
yep AFAIK they go through the square body and into the bracket. You have a non ABS model?
November 20, 2009, 09:26:03 am
Makebeleaf
November 20, 2009, 09:26:03 am »
Yes...non ABS....I wonder If I go to a wrecker and take a reciprocating saw and cut off the bracket that it is attached to?
Then I can work on it when I get it home.
General Information
Troubleshooting
