Author Topic: Setting IP with dial gauge -Specs found !  (Read 7285 times)
November 07, 2009, 02:04:51 pm
  • 1739
« on: November 07, 2009, 02:04:51 pm »
This is a follow up to a post i did in troubleshooting. i am have problems getting a rebuilt pump to run on a 1997 passat. I am looking for any reference as to what i can set the pump at with a gauge [like am IDI] before running it and setting the timing with my vag-com.
« Last Edit: November 13, 2009, 02:40:45 pm by the caveman »
Reply #1November 09, 2009, 04:07:19 pm
  • 1739
Re: Setting IP with dial gauge
« Reply #1 on: November 09, 2009, 04:07:19 pm »
Well i will  be certain to post what i find.
Reply #2November 13, 2009, 02:40:24 pm
  • 1739
Re: Setting IP with dial gauge Specs found !
« Reply #2 on: November 13, 2009, 02:40:24 pm »
Okay i won't mention here how i got it running BUT i did find a tech bulletin for my question. Tech bulletin group 23 #97-03 from august 15 1997 mentions that it can be set at .7mm + or - .05 mm. Problem is that the size of the fitting on the pump isn't the same as an IDI pump. The early pumps [and the tool] have a thread of 8mm with a 1.0 pitch where as the TDI [at least the 1Z passat i was working on ] has a thread of 10 mm with a 1.0 pitch. I will make a tool  adaptor in the future , but at least there is some sort of spec for it.
See my post in troubleshooting for the " fix "
Reply #3November 14, 2009, 10:26:09 am
« Reply #3 on: November 14, 2009, 10:26:09 am »
Problem is that the size of the fitting on the pump isn't the same as an IDI pump. The TDI has a thread of 10 mm with a 1.0 pitch.
All of the TDI pumps we have in the shop use this style.
Reply #4November 14, 2009, 10:44:13 am
  • 1739
Re: Setting IP with dial gauge -Specs found !
« Reply #4 on: November 14, 2009, 10:44:13 am »
Which stlye are you talking about ? the fitting for the gauge tool ?
BTW how's my pump coming along ,if you actually got my old one  yet ?
Reply #5November 14, 2009, 01:05:42 pm
Baxter
« Reply #5 on: November 14, 2009, 01:05:42 pm »
Brake line fittings are M10x1.
Reply #6November 14, 2009, 01:08:20 pm
  • 3255
    • My collection of HOWTOs
« Reply #6 on: November 14, 2009, 01:08:20 pm »
...as are oil pressure and coolant temp sensors.  An old brake fitting / sensor and an 8mmx1 tap builds you an adapter.  ;)
Reply #7November 14, 2009, 07:19:16 pm
« Reply #7 on: November 14, 2009, 07:19:16 pm »
Your pump is almost built. It should be on the test stand on monday.
Reply #8November 15, 2009, 07:21:51 am
  • 1739
« Reply #8 on: November 15, 2009, 07:21:51 am »
Vincent and Baxter-thanks. I may fit one up for the future. But i/m wondering if i'll ever run into such a problem again. Of course i shouldn't talk too soon, there will probably be one in this week.
And Tyler-AWESOME !
Reply #9December 09, 2009, 08:52:31 pm
Tintin
  • 1279
« Reply #9 on: December 09, 2009, 08:52:31 pm »
I do it often in the past with a dial indicator, usually between .70 to 1.00mm
The adaptor for TDI already exist in some kit, I see it on Ebay.
