General Information
General
Turbo Maps
Topic: Turbo Maps (Read 5413 times)
October 07, 2005, 05:04:57 am
Justin
Turbo Maps
October 07, 2005, 05:04:57 am »
Hey Guys I might have the opportunity to get a nice IHI Turbo for my rabbit but I must convince my boss to give it to me, he thinks that its to big and I think that its just the right size for a turbo 1.6 diesel. does anyone have turbo maps of stock or slight performance upgraded turbos?
Thanks in advance
Justin
www.archeryprostaffmi.com
October 07, 2005, 05:47:46 am
Maarten
Turbo Maps
October 07, 2005, 05:47:46 am »
Search google:
http://www.google.nl/search?hl=en&q=ihi+flowmap
first hit :wink:
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 07, 2005, 06:07:04 am
Justin
Turbo Maps
October 07, 2005, 06:07:04 am »
So what turbos come stock on vw turbo 1.6 and 1.9's?? then i can compare maps.
thanks
Justin
October 07, 2005, 06:48:33 am
Maarten
Turbo Maps
October 07, 2005, 06:48:33 am »
Sorry to say again but did you see the searchbutton on this forum?
http://www.vwdiesel.net/phpBB/search.php
Stock turbo 1.6td will give a lot of results
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 07, 2005, 07:23:44 am
Justin
Turbo Maps
October 07, 2005, 07:23:44 am »
Thanks i should have thought of that
October 07, 2005, 07:30:27 am
Maarten
Turbo Maps
October 07, 2005, 07:30:27 am »
If you may find the map for the stock T3 and K24 somewhere, please post them because the only maps I've found on the forums/internet are the T3 trim40 and up, and nothing about the stock K24.
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 07, 2005, 11:11:29 am
Master ACiD
Turbo Maps
October 07, 2005, 11:11:29 am »
i have the k24 map around here somwhere. i cant seem to find it though but i will keep looking.
October 07, 2005, 01:41:15 pm
Maarten
Turbo Maps
October 07, 2005, 01:41:15 pm »
Quote from: "Master ACiD"
I hope you can find it
Audi A3 TDI '98
VW cabby '79
VW T3 1.9TD '91
October 19, 2005, 09:53:20 pm
Master ACiD
Turbo Maps
October 19, 2005, 09:53:20 pm »
this is labeled as a k24 compressor map, if it helps any?
October 20, 2005, 11:19:11 am
fspGTD
Turbo Maps
October 20, 2005, 11:19:11 am »
Our 1.6lTD K24 compressor has a smaller inducer bore and likely less airflow capability than that there 2470GGA compressor map.
I believe that the correct compressor map describing our 1.6lTD K24 turbo would be designated 2460GW.
Jake Russell
Dieselicious
Turbocharger Upgrade/Rebuild Kits
October 20, 2005, 11:32:12 am
vwmike
Authorized Vendor
Turbo Maps
October 20, 2005, 11:32:12 am »
this is the place for compressor maps and all kinds of calculations for your engine:
http://not2fast.wryday.com/turbo/maps/
General Information
General
Turbo Maps
