TDI Engine -General Info
How long to remove the head on an 01 jetta TDI?
Topic: How long to remove the head on an 01 jetta TDI? (Read 11338 times)
October 01, 2009, 04:48:14 pm
topless96
October 01, 2009, 04:48:14 pm »
Anyone have an idea as to how many hours to take off the head for a 01 jetta? trying to decide if I should remove the motor tranny combo and rebuild or just fix the head. timing went off from loose cam bolt I was told. it would be a good time to build a good motor, but also might just be worth getting on the road.
October 01, 2009, 05:03:08 pm
Re: How long to remove the head on an 01 jetta TDI?
October 01, 2009, 05:03:08 pm »
Personally i could get it off in less than 1 1/2 hrs. [ faster if i use the impact gun for the head bolts !
Really not too hard
October 01, 2009, 08:24:28 pm
diesel smoke
October 01, 2009, 08:24:28 pm »
Few hours. WAY easier than an IDI.
'99.5 Bora TD
I
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
October 02, 2009, 03:43:59 am
topless96
October 02, 2009, 03:43:59 am »
What is the tool size for the head bolts? I think new studs are in order at this time as I plan on some mods at least until my check book screams.
October 02, 2009, 02:06:09 pm
October 02, 2009, 02:06:09 pm »
You may have to pull the valve cover before anything , they head bolts might be a new configuration- kinda like squared off torx.
October 02, 2009, 06:26:25 pm
diesel smoke
October 02, 2009, 06:26:25 pm »
They take 12mm tripple square/12 point. Same as a IDI.
'99.5 Bora TD
I
'88 Fox Coupe
'85 Mercedes 300SD
October 03, 2009, 03:55:33 am
topless96
October 03, 2009, 03:55:33 am »
Thanks, wasn't sure seemed to fit but had to tap on with a hammer
October 03, 2009, 07:30:38 am
oldskool rich
October 03, 2009, 07:30:38 am »
so you bent valves? or will it still run?
obviously if the timing has slipped you wont need to take the head off unless its bent sumit
are you talking about an ALH? head off is mega easy
f6squared I.D.S.T
October 03, 2009, 08:30:52 am
October 03, 2009, 08:30:52 am »
Quote from: diesel smoke on October 02, 2009, 06:26:25 pm
You're right, for some reason i thought we were talking about a newer model.
October 18, 2009, 03:18:18 pm
topless96
October 18, 2009, 03:18:18 pm »
I was, it's a 2000 TDI. Sorry was away on business for a week. I guess form what it looks like, it comes out from the bottom. I guess I will see if I can do it this week. can't find any How to on the sites.
October 20, 2009, 04:30:43 am
rubadubdub
October 20, 2009, 04:30:43 am »
Try this site. There are loads of how tos with pictures.
think this is the page for yours
http://www.myturbodiesel.com/1000q_how_to/a4/a4_how_to_index.htm
the main page is here:
http://www.myturbodiesel.com/1000q.htm
Hope that helps
1991 Mk2 Golf GTD
Reply #11
October 21, 2009, 04:16:09 pm
topless96
Reply #11 on:
October 21, 2009, 04:16:09 pm »
Thanks, great info on that link. will come in handy.
Reply #12
November 18, 2009, 02:25:38 am
Smokey Eddy
Reply #12 on:
November 18, 2009, 02:25:38 am »
Hmmm everyone says its so easy to take the head off an ALH...
I was thinking about changing the HG on my parents TDI and maybe cleaning the head up a bit. checking how the valves seat.
Are there any special tools or tricks to remember?
http://www.myturbodiesel.com/1000q_how_to/a4/head_removal.htm
What a great site!
Last Edit: November 18, 2009, 02:28:27 am by Smokey Eddy
Ed
THROWN ROD
Reply #13
November 18, 2009, 08:30:39 pm
diesel smoke
Reply #13 on:
November 18, 2009, 08:30:39 pm »
About the only special tool you need is the 12mm 12 point socket. Why do you want to do the HG on the car? Is there a problem? If not, why do it?
'99.5 Bora TD
I
'88 Fox Coupe
'85 Mercedes 300SD
