Author Topic: How long to remove the head on an 01 jetta TDI?  (Read 11490 times)
October 01, 2009, 04:48:14 pm
topless96
  • 58
« on: October 01, 2009, 04:48:14 pm »
Anyone have an idea as to how many hours to take off the head for a 01 jetta? trying to decide if I should remove the motor tranny combo and rebuild or just fix the head. timing went off from loose cam bolt I was told. it would be a good time to build a good motor, but also might just be worth getting on the road.
Reply #1October 01, 2009, 05:03:08 pm
  • 1739
Re: How long to remove the head on an 01 jetta TDI?
« Reply #1 on: October 01, 2009, 05:03:08 pm »
Personally i could get it off in less than 1 1/2 hrs. [ faster if i use the impact gun for the head bolts ! ;D].
Really not too hard
Reply #2October 01, 2009, 08:24:28 pm
diesel smoke
  • 209
« Reply #2 on: October 01, 2009, 08:24:28 pm »
Few hours. WAY easier than an IDI.
'99.5 Bora TDI
'88 Fox Coupe
'71 Tin Top Westfalia Bus
'85 Mercedes 300SD
Reply #3October 02, 2009, 03:43:59 am
topless96
  • 58
« Reply #3 on: October 02, 2009, 03:43:59 am »
What is the tool size for the head bolts? I think new studs are in order at this time as I plan on some mods at least until my check book screams.
Reply #4October 02, 2009, 02:06:09 pm
  • 1739
« Reply #4 on: October 02, 2009, 02:06:09 pm »
You may have to pull the valve cover before anything , they head bolts might be a new configuration- kinda like squared off torx.
Reply #5October 02, 2009, 06:26:25 pm
diesel smoke
  • 209
« Reply #5 on: October 02, 2009, 06:26:25 pm »
They take 12mm tripple square/12 point. Same as a IDI.
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
Reply #6October 03, 2009, 03:55:33 am
topless96
  • 58
« Reply #6 on: October 03, 2009, 03:55:33 am »
Thanks, wasn't sure seemed to fit but had to tap on with a hammer
Reply #7October 03, 2009, 07:30:38 am
oldskool rich
  • 446
« Reply #7 on: October 03, 2009, 07:30:38 am »
so you bent valves? or will it still run?
obviously if the timing has slipped you wont need to take the head off unless its bent sumit
are you talking about an ALH? head off is mega easy
f6squared I.D.S.T
Reply #8October 03, 2009, 08:30:52 am
  • 1739
« Reply #8 on: October 03, 2009, 08:30:52 am »
You're right, for some reason i thought we were talking about a newer model.
Reply #9October 18, 2009, 03:18:18 pm
topless96
  • 58
« Reply #9 on: October 18, 2009, 03:18:18 pm »
I was, it's a 2000 TDI. Sorry was away on business for a week. I guess form what it looks like, it comes out from the bottom. I guess I will see if I can do it this week. can't find any How to on the sites.
Reply #10October 20, 2009, 04:30:43 am
rubadubdub
  • 109
« Reply #10 on: October 20, 2009, 04:30:43 am »
Try this site.  There are loads of how tos with pictures.
think this is the page for yours
http://www.myturbodiesel.com/1000q_how_to/a4/a4_how_to_index.htm
the main page is here:
http://www.myturbodiesel.com/1000q.htm
Hope that helps
1991 Mk2 Golf GTD
Reply #11October 21, 2009, 04:16:09 pm
topless96
  • 58
« Reply #11 on: October 21, 2009, 04:16:09 pm »
Thanks, great info on that link. will come in handy.
Reply #12November 18, 2009, 02:25:38 am
Smokey Eddy
  • 3468
    • McScrubbins Body Wash
« Reply #12 on: November 18, 2009, 02:25:38 am »
Hmmm everyone says its so easy to take the head off an ALH...
I was thinking about changing the HG on my parents TDI and maybe cleaning the head up a bit. checking how the valves seat.
Are there any special tools or tricks to remember?
http://www.myturbodiesel.com/1000q_how_to/a4/head_removal.htm
What a great site!
« Last Edit: November 18, 2009, 02:28:27 am by Smokey Eddy »
Ed
Reply #13November 18, 2009, 08:30:39 pm
diesel smoke
  • 209
« Reply #13 on: November 18, 2009, 08:30:39 pm »
About the only special tool you need is the 12mm 12 point socket. Why do you want to do the HG on the car? Is there a problem? If not, why do it?
'99.5 Bora TDI
'88 Fox Coupe
'85 Mercedes 300SD
