General Information
Troubleshooting
A/C clutch???
Topic: A/C clutch??? (Read 3658 times)
July 03, 2009, 06:31:57 am
Kneale Brownson
A/C clutch???
July 03, 2009, 06:31:57 am »
Is it possible to replace the magnetic clutch on the A/C compressor on a 1995 Jetta TD? The clutch isn't engaging.
I'd like to avoid going through all the evac/flush/replace expensive drier/etc. in order to replace the whole compressor because the clutch isn't functioning.
I've replaced just the clutch without opening the system on an Audi.
July 03, 2009, 12:11:37 pm
Zulfiqar
Re: A/C clutch???
July 03, 2009, 12:11:37 pm »
yes it is - you would need a sanden puller to remove the clutch assy from the compressor hub - I think a bolt also works just dont know the size
u sure the clutch is gone? maybe you are just missing a ground connection to it
Diesel IS the future
July 03, 2009, 03:16:08 pm
Kneale Brownson
Re: A/C clutch???
July 03, 2009, 03:16:08 pm »
I had power to the connector.
Don't remember whether I hooked my test light to the ground in the connector, though. I should recheck the continuity of the connector ground to the chassis, I guess.
General Information
Troubleshooting
A/C clutch???
