Author Topic: A/C clutch???  (Read 3707 times)
July 03, 2009, 06:31:57 am
Kneale Brownson
  • 120
A/C clutch???
« on: July 03, 2009, 06:31:57 am »
Is it possible to replace the magnetic clutch on the A/C compressor on a 1995 Jetta TD?  The clutch isn't engaging.
I'd like to avoid going through all the evac/flush/replace expensive drier/etc. in order to replace the whole compressor because the clutch isn't functioning.
I've replaced just the clutch without opening the system on an Audi.
Reply #1July 03, 2009, 12:11:37 pm
Zulfiqar
  • 254
Re: A/C clutch???
« Reply #1 on: July 03, 2009, 12:11:37 pm »
yes it is - you would need a sanden puller to remove the clutch assy from the compressor hub - I think a bolt also works just dont know the size
u sure the clutch is gone? maybe you are just missing a ground connection to it
Diesel IS the future
Reply #2July 03, 2009, 03:16:08 pm
Kneale Brownson
  • 120
Re: A/C clutch???
« Reply #2 on: July 03, 2009, 03:16:08 pm »
  I had power to the connector.
Don't remember whether I hooked my test light to the ground in the connector, though.  I should recheck the continuity of the connector ground to the chassis, I guess.
