Author Topic: Buying an Engine Need Advice  (Read 5126 times)
June 27, 2009, 12:29:05 pm
SolarSteve
  • 264
« on: June 27, 2009, 12:29:05 pm »
I am considering buying a 1.6l turbo engine with hydro head from a guy a I have never met a few hours away from me.  What do I need to look for to be sure this is in fact a turbo block?  Besides a gapping hole in the side of the block what else should I look for or signs to cause me to steer clear?
Oh yeah, the head is of the block so I should be able to see the piston tops and inside the bores.  I plan to try to rotat the crank as well.
Thanks!
Steve
91 Jetta 1.6 N/A
Reply #1June 27, 2009, 01:29:02 pm
rabbitman
  • 2788
Re: Buying an Engine Need Advice
« Reply #1 on: June 27, 2009, 01:29:02 pm »
Look at the two letter engine code on the front of the block just below the headgasket and inline with the #3 cylinder, I think CY, MF, SB, 1V is an ecodiesel block but IIRC it has piston coolers also, I don't think SB ever made it over the pond so I doubt it's that.
Some others hopefully will chime in and let fly some more info.
Reply #2June 27, 2009, 06:16:24 pm
SolarSteve
  • 264
« Reply #2 on: June 27, 2009, 06:16:24 pm »
Thanks.
I forgot to mention that the seller says that this turbo motor is out of his 1986 Golf.  I don't know if that helps narrow this down any.
Steve
91 Jetta 1.6 N/A
Reply #3June 27, 2009, 06:20:37 pm
rallydiesel
  • 1880
« Reply #3 on: June 27, 2009, 06:20:37 pm »
I would pull the head and make sure the bores aren't trashed and on the third overbore. Because then you 'd basically be buying a really big paperweight.
1991 Jetta TD - sold :(
2001 Golf TDI - Son's
Reply #4June 27, 2009, 06:49:39 pm
SolarSteve
  • 264
« Reply #4 on: June 27, 2009, 06:49:39 pm »
How will I be able to tell if the the motor has ever been bored?
Steve
91 Jetta 1.6 N/A
Reply #5June 27, 2009, 06:59:07 pm
rallydiesel
  • 1880
« Reply #5 on: June 27, 2009, 06:59:07 pm »
Easiest way would be to rub the soot off the top of the piston and read the number. Otherwise you could use a bore gauge.
Reply #6June 27, 2009, 07:03:20 pm
SolarSteve
  • 264
« Reply #6 on: June 27, 2009, 07:03:20 pm »
OK, I know the pistons are numbered I,II,III,IV.  So what will they be if it has been bored?
Steve
91 Jetta 1.6 N/A
Reply #7June 27, 2009, 08:09:53 pm
rallydiesel
  • 1880
« Reply #7 on: June 27, 2009, 08:09:53 pm »
Standard size: 76.48
1st overbore: 76.73
2nd overbore: 76.98
3rd overbore: 77.48
One of these four sets of numbers will be stamped on the top of the piston.
