Reuben, Is your pump a Land rover tdi? No matter what i do i can't get the pulley to line up, not even close. i have the same pulley as you too!
Did your family mention that they got the nozzles?
Ryan
All I can tell you is my set up & hope it helps... I took an AAZ pump bracket, bored it out to fit the LR pump snout, pressed on the TDI taper shaft sprocket adapter & bolted up a TDI sprocket I got from Prothe. You're not using the LR sprocket adapter by any chance?? No word from the cousins yet.
Ahh, It looks like that is my problem!! I thought about changing the adaptor but no one mentioned it before, I'll go pick one up today!
Ryan
