Got this from the diesel shop. Hope it helps.
Ooh! I like this very much, well snaffled!
That transfer pressure figure of 4.6 to 5.2 bar (66.7 to 75.4 psi) at 3000rpm engine is going to be very useful.
Sweet Now i need a pump bench. I wish i could just have one avail to use. I could play with so much and it would no longer be guess work.
so how would you get the pressure curve of the yellow dot? you would need the regulator from it with the matching advance spring?
I don't know but I can get more info on that.
yes, im sure thats how you would do it..
but i dont think i would want a 1.5 advance curve.. they are like, all advanced way too soon in my opinion..
why not use the stock advance setup so you actually have some advance left up top?
As long as the total advance is the same it wouldn't make a difference at high rpm. You would have more marbles at lower rpm though.
