Author Topic: New Sachs clutch w/install kit, trans, waterpump, Bentley  (Read 4338 times)
February 09, 2009, 02:48:11 pm
Spulen81
  • 103
« on: February 09, 2009, 02:48:11 pm »
New in box 200mm Sachs clutch kit.  Will fit and A1 or A2 with a 200mm clutch.
SOLD
Comes with:
-alignment tool
-thrust plate and retainer clip
-input and pushrod seal
-pushrod bushing
-crank bolts and PP bolts
-throw out bearing
AGS 5 speed, has .75 fifth. From a diesel but ratio wise it would work fine in a gas car. I have to verify the code but I'm pretty sure. $150 pick up only
New Graf waterpump, the good kind. $SOLD,
MK2 Bentley $SOLD
'86 4Runner TDI SOLD
'91 GTI - TDI converted
Reply #1February 09, 2009, 08:14:42 pm
Dakotakid
  • 1240
« Reply #1 on: February 09, 2009, 08:14:42 pm »
Are you parting out an '86 car by chance? Are you letting go of the fuel pump?
Reply #2February 10, 2009, 06:44:28 am
Spulen81
  • 103
« Reply #2 on: February 10, 2009, 06:44:28 am »
I am actually.  Make me an offer on the injection pump I'm not sure what they are worth.  The car was running fine, the PO changed the t-belt and wiped out the valves.  Its only been sitting for a couple months.
Reply #3February 10, 2009, 10:24:27 am
Dakotakid
  • 1240
« Reply #3 on: February 10, 2009, 10:24:27 am »
PM'ed ya, I did.
Reply #4February 10, 2009, 11:13:51 am
GIDDY_UP_GO
  • 114
« Reply #4 on: February 10, 2009, 11:13:51 am »
How do you know if you have a 200mm clutch or not? I have an 86 Golf N/A Diesel with a 5 speed.
Also, what shape is the Bentley in?
86 MK2 Golf Diesel
Reply #5February 10, 2009, 11:31:20 am
Spulen81
  • 103
« Reply #5 on: February 10, 2009, 11:31:20 am »
You *should* have a 200mm, this kit was for an '86 diesel also.  Unless somebody swapped it out for a 210 at some point.  The Bentley is in good shape.  Its used but not super dirty or worn.  I can email you a pic if you want, just PM me you email address.
Reply #6February 26, 2009, 05:38:42 am
Spulen81
  • 103
« Reply #6 on: February 26, 2009, 05:38:42 am »
Bentley and waterpump are sold.
Reply #7March 16, 2009, 08:56:01 am
Spulen81
  • 103
« Reply #7 on: March 16, 2009, 08:56:01 am »
Only the trans is left.  It is an AGS for sure also.
